Question about Gigabyte GA-8IHXP Motherboard
GA-8IHXP won't boot... VER 3.0
HI
THIS IS NOT A NEW SYSTEM, IT'S BEEN UP AND RUNNING FOR YEARS WITH NO PROBLEMS. THE PC WAS RUNNNG AND THE SCREEN JUST WENT BLACK (NO SIGNAL). NOW AS I TRY TO BOOT, THERE IS NOTHING AT ALL ON THE SCREEN WITH THE SCREEN INDICATING NO SIGNAL.
THE ACTIONS I HAVE TAKEN TO REMEDY THIS PROBLEM ARE AS FOLLOWS
1. CHANGED POWER SUPPLY & TESTED THE OLD ONE WHICH IS OK.
2. CLEARED THE BOARED OF ALL CABLES & CARDS EXCEPT GRAFICS CARD, KEPT ALL DRIVES POWERED UP
3. CHANGED GRAFICS CARD - TESED OLD CARD WHICH IS OK TOO.
4. CLEARD CMOS & REMOVED BATERY
SUMMERY
THE POWER SWITCH IS GOOD AS PC IS TURNED ON, THE M/B LIGHT COMES ON BUT IT HANGS IN LIMBO WITH BLACK SCREEN (NO SIGNAL ) PC IS TURNED OFF ONLY BY HOLDING DOWN PWR SWITCH OR CUTTING OFF POWER VIA POWER SUPPLY ON/OFF SWITCH.
IF ANYONE HAS ANY IDEAS, PLEASE SHARE THEM WITH ME.
THANKS GUYS
TONY
  • 1 more comment
  • tony10156 May 23, 2009
    HI
    THE ADVISE YOU GAVE IS SOUND, UNFORTUNETLY I FAILED TO MENTION IN MY COMMENT THAT ALL CAPACITORS LOOK GOOD. THE (BUBBLING EFFECT) WHICH WOULD APPEAR ON THE TOP SIDE OF A BLOWEN CAPACITOR DOES'NT APPEAR ON ANY OF MINE. JUST TO BE SURE I WENT AT IT WITH A MAGNIFYING GLASS. ALSO I HAVE NO WAY OF TESTING THE RDRRAM SO I REPLACED THEM WITH THE RIMMS, 1 PAIR AT A TIME AND THEN BOTH PARES, NO CHANGE, THE PROBLEM IS THE SAME.. I'M NOW GOING TO RESEAT THE CPU, JUST ONE MINUTE AND I'LL TELL YOU THE RESULTS OF THAT TOO. NOPE, HAD NO AFFECT. PC IS STILL AS BEFORE. THANK YOU FOR TAKING THE TIME TO RESPOND. I AWAIT YOUR COMMENT / ADVICE.
    TONY
  • tony10156 May 24, 2009
    SORRY. YOU ARE CORRECT, MY MISTAKE THEN. IT JUST DID NOT FIX THE PROBLEM.
    DO YOU THINK THE M/B GONE TO HEAVEN. AS THIS M/B IS VERY HARD TO FIND NOW A DAYS, I FOUND ONE ON EBAY VER 2.1 AS MINE IS VER 3.0. I KNOW THERE'S A SOUND DRIVER DIFFERENCE BUT THE RDRRAM SHOULD BE INTERCHANGEABLE RIGHT??
    THANKS FOR YOUR TIME AND ADVICE. I'LL CONCIDER MY OPTIONS.
    HAVE A GOOD ONE.
    TONY
    President:
  • 948 Answers
The next thing I would check is a close inspection of all the bad capacitors on the board. If you need an idea of what they look like check here.
Posted on May 23, 2009
  • Dick
    Dick May 23, 2009
    The next thing I would do is fix the rating you assigned. You said in your comment the advice was sound, but you left out information in your post. You will see the CHANGE RATING link on this page, most likely just under my answer. If you review the ratings FAQ you will see my answer should have been rated helpful since it was sound advice but did not fix your problem.
  • Dick
    Dick May 24, 2009
    I do suspect the motherboard is dead. Yes, the RIMMs will still work in the older version of the board.
    Also keep in mind that sometimes the capacitors will blow out on the bottom. But it would be pretty unlikely that you would not notice any of them bubbled on the top if bad caps were the problem. Might be worth another look if the board is that important to you. I would just replace the whole thing.
GA-EP43 -UD3L motherboard will not boot with 16 GB of memory
Time to RMA, sounds like you have a faulty memory channel on the MB. Possibility the slots are not getting enough power to handle all 4, you try to see if you can increase power in bios.
Mar 01, 2017 | Gigabyte GA-EP45-UD3L Motherboard
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
I have had a variety of problems since 2007 a few months after I puchased this gateway laptop from HSN. Big mistake. Customer service for Gateway is terrible! The battery will not charge, screen fails...
Let's think about this. The computer is 3 years old, probably running Vista. It needs a new battery, not surprising on a 3 year old system. The screen doesn't work for some reason.
A battery & screen will run you $150-200. It may still have a problem.
A new computer with Win7 is $400-500.
I know what I would do.
Sep 21, 2010 | Gateway Computers & Internet
I have a HCL Monitor Model HCM782M.For the past 2 years since i bought it the screen was fine.But now the screen shows the CONTRAST SETTING everytime I boot my pc and keeps up popping up ver very qucikly.I...
Mr Ajit in my organisation I have around 20 such monitors which have the same error. This happens due to moisture the mewnu PCB gets shorted and now you are left with only two solution either disconnect the menu pcb from the main board or replace it with a new one
Aug 17, 2010 | Computers & Internet
I have an msi ms-7390 k9n sli ver 2 motherboard and I updated the bios to the latest ver. 1.2. After that when cold booting the motherboard does not initialize usb you have to press delete to enter setup...
move the sata connection for your bootable HDD to another port like 3 or 4 and the bios will detect then run bios setup to boot from the sata 3 or 4 and it works like normal, must be a bug in sata 1 and 2. had same issue trying to install win7 x64. Win 7 refuses to detect sata DVD drive, moved it on the MB and it installed fine.
Jul 19, 2010 | MSI K8N Neo4-F Motherboard
Gigabyte GA-VM900M and Inno3D GeForce 7300
just reinstall the operating system.
dont forget to vote
Sep 16, 2009 | Gigabyte GA-VM900M Motherboard
Long POST and will not mount HDD.
first of all, you need to another 512Mb of memoires. it will run better. second, go to BIOS and search for boot order, chaneg the the boot order to Hard driver first.
May 01, 2009 | Computers & Internet
New Build PC not booting
do you get any onscreen information like a bios screen?
Feb 22, 2009 | Gigabyte GA-M57SLI-S4 (4719331821180)...
BIOS
Restore the BIOS with the old version
Nov 02, 2008 | Gigabyte GA-8I945G Pro Motherboard
Broken resistance on a GA-8IHXP (rev3) mobo
Its a resistor. The colored bands show exactly what the specs are.
Here is a page to show you how to read it.
http://wiki.xtronics.com/index.php/Resistor_Codes
If you take it out radio shack should be able to match it up for you.
Dec 22, 2007 | Gigabyte Technology: Technology ATX Intel...
Gigabyte GA-8IHXP Motherboard Logo
143 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
