Question about Frigidaire GLTF1670A Front Load Washer
Makes clunking sounds & throws belt off pulley.
Throws belt off pulley & makes clunking sounds.  Works fine (albeit with the loud clunking noise) until it throws the belt, so all the electronics are OK.  I've replaced the belt, but the same problem occurs.  Also, the drum seems to be difficult to spin by hand.  Drum bearings? Shocks?  Is this a car or a washer??  THANKS.
  • Pitchoun Oct 19, 2007
    Thanks!  After some more investigation, it is clearly the bearings.  Bad news, but good to know what's what.
  • Anonymous Mar 16, 2014
    Replaced clutch about 2 months ago. Has worked fine until now. Drum does not spin freely by hand, spins slowly under power and makes a rhythmic clunking noise.
  • 64 Answers
I think you have the answer. I suspect it will be the bearings that have seized up. Or possibly the spyder / drum axle broken
Posted on Oct 19, 2007
Riding mower makes noise and has a vibration when I engage mower blades and throws the belt off
Normally, this is caused by a bad / or worn out bearing in the blade spindle. The blade is attached to a shaft that goes thru the spindle housing, where the bearings are located, and then goes to the pulley that is driven by the blade drive belt. good luck
Jul 21, 2017 | Garden
My 1997 chrysler t &c is making a loud clunking noise, steers hard and overheats. Mechanic says it's tension pully. does that sound right
It sounds like it to me. Your van has a serpentine belt which is pulled tightly by the tensioner pulley, hint the name "tension" pulley. If this is defective you will experience the problems/symptoms you have listed, hard steering, over heating, and the clunking,which must be the defective tension pulley. All those problems should resolve immediately after it is replaced. Don't forget to replace the serpentine belt too, for preventative measures. How this helps...
Jul 25, 2014 | 1997 Chrysler Town & Country
Loud in spin cycle/throws oil
If the pulley wobbles, it sounds like a bad bearing, and that could account for the oil/grease. One more thing you might check, mine acted bad in the spin cycle, but mine was the leveling spring at the bottom of the drum. The way to tell from the top is if the drum tends to lean forward instead of being centered when sitting. Good luck.
Jan 08, 2018 | Maytag MAH55FLB Front Load Washer
I put on a new fan belt and it makes a squeaking noise after just a few months....why is this......the engine is a 4.3 L G20 chevy van 1994 without AC
Could be a pulley making the noise. Could be your choice of belts. I have had good luck with the Goodyear Gator Back belts. And I don't care if someone says their store brand is made by Goodyear. They may be what Goodyear throws away and the store goes dumpster diving for them.
Its harder to do on a van but what you can try if you don't have an automotive stethescope is hold a piece of hose to your ear and the other end around the pulleys to help you narrow down where the noise comes from..
Sep 09, 2011 | Chevrolet G20 Cars & Trucks
Kenmore series 80 dryer. everything works fine so far, just makes like a rumble noise as it is drying. driving me crazy. any solutions?
THE NOISE COULD BE FROM MANY THINGS. IS THE DRYER SITTING ON THE FLOOR SECURELY? HAVE YOU CHECK THE BAFFLE INSIDE THE DRUM? IS THE NOISE LIKE A CLUNKING NOISE AS THE DRUM TURNS? ALSO THE BELT MIGHT BE OFF ALIGN FROM THE MOTOR PULLEY, EVENTUALLY IT WILL TEAR OFF THE BELT.
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH THE PROCESS IF NEEDED.
Jan 16, 2010 | Kenmore Dryers
The dryer makes a loud noise when running. It still works and drys. Its a loud screeching sound. Do you think the belt needs to be replaced?
Could be the one of the 4 drum rollers, Idler pulley or belt.
I usually replace them all at once for long term reliability.
Jan 08, 2010 | LG DLE3777 Electric Dryer
1993 mercury topaz GS Engine noise
Another guess would be the water pump going bad. That noise can be loud when it gets pretty bad and makes like a metal on metal grinding noise
Nov 06, 2008 | 1993 Mercury Topaz
Oki C9500 makes VERY LOUD clunking noises but prints fine...
The sound is most probably from one (or more) of the drum units. You can check by taking them out and trying to run the visible gears by hand. If you have spare drums, change them one at a time until you find the defective one.
Sep 04, 2007 | OKI C9500dxn Led Printer
Frigidaire GLTF1670A Front Load Washer Logo
235 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
