Question about Toshiba 50H82 50" Rear Projection Television
No picture, no sound, but has power light...any suggestions? thx in advance
Hi, I noticed your expertise on another posting. I have a toshiba 50h82 projection tv. I was watching it one night and thought a dog stepped on the remote control (no picture, no sound), but the power light was still on. Unplugged/replugged, same results...any suggestions? From the previous answer it appears she may be DOA?
  • 3 more comments
  • humorme7 May 23, 2009
    I tried to turn it on to change an input and nada....no menu. So by dead you mean I've got this huge black box with a plastic screen that's useless, right? :) thx for quick response
    Nope, can't get anything with the remote either
    Tried what is mentioned above...no picture or sound or menu either thru using the remote or the button on the front of the tv. It just clicks like the power is turning on, but nothing else. Tried plugging into various inputs on the back of tv with no success.
  • John Snow
    John Snow May 11, 2010
    Can you pull up the menu with the remote?
    Let me know.
  • shawn rogge May 11, 2010
    if you unplugged it complteley from cable and poweroutlet its probly dead, sorry.what happens if you swittch inputs?
  • 110 Answers
Do this first:
1: Check the antenna/cable connections.
2: Press the TV/VIDEO on the remote control or the TV to view a signal coming from another device connected to your TV, such as a VCR or
video disc player. You can select ANT 1,
VIDEO 1, VIDEO 2, VIDEO 3, ColorStream HD1, ColorStream HD2, or ANT 2 depending on which input jacks are used for connecting the devices.
*Be sure you have the right source to view video.
Try the above and post back before I can say there is a problem with your unit. If you have the user manual it's a good time to get it out. If you don't have it let me know and I will give you a link to obtain it. Good luck!!
Posted on May 23, 2009
The picture on our Toshiba 50H82 rear projection tv is shaky, any diy solutions for this?The picture will sometimes clear up after about 30 minutes. Can this be fixed? The sound is fine, it's just the...
Thats almost always caused by the surface mount capacitors which get weak on the hyper board. Hyper boards are going to be hard to find. But the capacitors can be replaced which will usually solve the issue. However it will require precise soldering skills to do the repair.
Oct 06, 2011 | Toshiba 50H82 50" Rear Projection...
We have a rear projection tv that has no sound or picture after a power outage??
Suggest unplugging for 15-30 min to allow capacitors inside to discharge and reset and systems from the outage. Then plug in and see. It could be the power supply or a burned out bulb from the quick pulse of loss of power also.
Apr 26, 2010 | Toshiba 50H82 50" Rear Projection...
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
No picture or sound
Hi,do you hear clicking or like wanting to turn on?If you do it could be an issue with the ballast that is the board that powers the lamp.If you dont hear that and tv is between 2-4 yrs most likely its time to replace lamp.Make sure you Get the Philips brand.God bless you and your house.
Oct 01, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 rear projection TV adjustment
The ser needs to be converged in the factory service mode
Jan 14, 2009 | Toshiba 50H82 50" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
No picture
hi!
you can download the power dvd player.
because other computer you can play and hear the sound but no picture.
PS:
pls rate if is invaluable solution rate me fixya.
thx
May 22, 2008 | Toshiba SD-P1400 Portable DVD Player
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
Red gun gone...
STK392-110T X 2 in TOSHIBA , Do not use generics.If you
want to upgrade = STK394-160E = I use Hitachi brand......T.
Oct 29, 2007 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 blown fuse f470
Solder jumper wires for prevent maintenance.....on signal
board = 008,010,017,048,600.............................T.
Oct 23, 2007 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
222 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
