Question about Toshiba Satellite A205-S4707 Notebook
Toshiba Satellite laptop does not power - no blue light to recogn
I tried getting the unit to reset - pulled battery nad still no blue charge light. Not sure what to do next. She also broke the locking latch and now appears to have fallen out?
any help is appreciated mgogola551@gmail.com
  • Anonymous May 24, 2009
    Power cord has always worked and when I plug in I can see the spark as I plug in to the jack. as for the receiver, it appears to be stationary and not loose. Any other suggestions??
  • Chuck Gluth
    Chuck Gluth May 11, 2010
    have you checked the power cord for proper voltage? and also check the dc jack in the laptop to make sure it isnt broken or loose?
  • 696 Answers
You should NEVER see sparks when connecting the AC adapter.
If you are seeing that there is damage in either the adapter, the AC plug or both although I would suspect internal damage in the plug.
Unless your handy with a sauldering iron I think this would be a good point to take it to a pro, they can test the AC adapter with a voltmeter and confirm or deny my suspicion. If I'm wrong the voltmeter will show wrong voltage for the unit, if I'm right it will be in tolerance and you'll know the AC plug is the most likely culprit.
Depending on the model and the repair shop these typically cost about $100-$200 to repair.
Chris
Posted on May 24, 2009
I have a Toshiba Satellite A105 laptop that will not power up.
Get sure the memories are good. then try reseting the BIOS by removing the BIOS batery, let it out for 5 minutes and place it again. Though you have to disassembly almost the whole laptop. If dont, chek the other "pheripheral" devices, HDD, DVD, and another (If)
Apr 20, 2010 | Toshiba Satellite A105-S4004 Notebook
Laptop suddenly stops recharging / recognizing the charger
Here is a manual....mostly replacement parts etc.
http://tim.id.au/laptops/toshiba/satellite%20and%20pro%20220%20440%20460%20470%20480.pdf
Sounds like your battery is shot, bad or discharged or shorted batteries will shut the charging circuit off.
Oct 16, 2009 | Toshiba Satellite Pro 470CDT Notebook
Toshiba Satellite A60 wont power up
It looks like some divece in your laptop dont pass POST test. Tech support from Toshiba required
Sep 23, 2009 | Toshiba Satellite A60 Notebook
Toshiba A70 laptop will not recognize battery
Take the battery out, remove the power cord and hold down the power button for 30 secs. This will reset your hardware settings and might just fix your problem. Plug it all in and give it a try.
Mar 24, 2009 | Toshiba Satellite A70-S249 Notebook
New battery charges but won't work
YOU HAVE A FUALT CONNECTION TO THE BATTARY AND NOTEBOOK POWER SUPPLY AND MAY BE A WIRE COME LOOSE INSIDE THE LABTOP
ROD
Feb 04, 2009 | Toshiba Satellite A105 Notebook
Toshiba laptop power light on but not working
Try this.Your VGA is problem or your battery is fully charge down.so please fully charge your battery atleast 8 hours and then press your power switch.it will on your loptop system.
plz Call 09944377607 V.RAJA
Jul 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Power up problem
it has nothing to do with the ram, it is the issue of the adapter or battery for toshiba laptop, if the output volatge form the adapter is not steady, the light will get yellow and blink,try it on another toshiba laptop. if it is normal, u should test the toshiba laptop battery by the multimeter, connect the electroprobes wiht the anode and cathode, if the pointer does not fixed in a short time ,the battery is the issue. change it for a new one.
Jun 27, 2008 | Toshiba Satellite 1410-S173 Notebook
Toshiba pro l10
try pulling the battery and turning the unit on, if it powers on then, it is a bad battery, if not, it may be a bad mobo or charging unit inside the laptop.
May 14, 2008 | Toshiba Satellite A135-S2386 Notebook
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A205-S4707 Notebook Logo
480 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
