Question about Canon FAXPHONE L170 Plain Paper Laser
Can't find switch to turn off ringer volume
I want to turn off the ringer on my Canon L170faxphone. I can't find the manual and don't see an "easy" button to do this, thanks!
  • amy3553 May 24, 2009
    Thanks! There is a "low to high" type icon on the handset, but no switch to move it. There is a ****, may be a toothpick would work.
  • 37 Answers
U will find that switch in the handset with three degree high,low and off the ringer.
Posted on May 23, 2009
  • eng_amgoda Jun 13, 2009
    yes u can use a toothpick it can work
How do you turn off the base ringer?
You don't have to unplug anything. Just set the ringer volume (feature code 11) to 0.
Full details are on page 27 of the manual.
Mar 16, 2012 | Panasonic KX-TG6022B Phone
How can I turn the ringer down?
RINGER VOLUME SWITCH
Use a pen or other pointed object to
select the ring volume of the handset (HI, LO, or OFF).
If you need the manual to see a picture of where the volume switch is located on the handset, send me an email to LBrown18062@hotmail.com I will send the manual to you right away. Please put CANON FAX L80 as the subject. Lawrence Brown
Oct 22, 2011 | Canon FAXPHONE L80 Laser
I somehow turned off the ringer and can't figure out how to turn it back on. I can't find my manual at the moment. Is there an easy way to both turn the ringer on and to turn it off?
Most modern phones have 2 buttons for volume control. This typically will change ringer volume (including vibrate / mute).
If that doesn't work, post your model number and we can give more exact answers.
Mar 17, 2011 | Cell Phones
How do I turn the ringer on? 5.8 EXI 5160 phone
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as
vol or vol) in standby mode to select one of five
ringer tones and volume combinations.
You can get the manual on link below page 19 will tell you how to set ringer volume.
http://www.uniden.com/pdf/EXI5160om.pdf
Dec 23, 2009 | Panasonic 5.8GHz Cordless Telephone
How do you turn ringer on and off on a uniden exi8560 cordless 5.8ghz
hello. To turn the ringer off on that phone you need to get into the menu. The way you get into the menu is press and hold the menu/cid button for 2 seconds. Then press the arrow down button until you highlight the ringer volume. once the ringer volume is highlighted, press the select/channel button. that will rotate you through the 3 available volume levels. High, low and off. as you are pressing the select/channel button the handset sounds a sample of the volume level. when you hear the volume level you want simply press end and that will store your volume to the off position. to turn it back on, just repeat the above steps but select the proper volume level you want and then hit end. I hope this helps.. Don;t forget to rate me. thanks !
Sep 07, 2009 | Uniden EXI8560 5.8 GHz 1-Line Cordless...
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
Model GE 27951 - Unable to Turn Ringer back on
The headset volume is turned to zero. Hit the "menu" key on the headset and it should take you to "ringer setting", hit select for the ringer volume and turn the volume up. Not very intuitive but that should get you going!
Jan 28, 2009 | General Electric 27951EE1 - - Phone
SCH-u410 Phone "All Sounds Mode Off Activated"
Press and hold down the # button until it says "exiting silent mode...
Apr 25, 2008 | Verizon Communications Samsung SCH-u410...
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Ringer volume
on the back of the base there is a volumr high low switch.
Aug 09, 2007 | Innovage 1502084 Corded Phone
Canon FAXPHONE L170 Plain Paper Laser Logo
307 people viewed this question
old marine
old marine
