I need detailed instructions to do this please
Need to remove air conditioner evaporator on a 1989 buick regal
  • mmosher744 May 23, 2009
    I know i can go buy a book,the whole purpose of asking was to try to get some free advise.Not everyone has money to pay for a manual or pay for a bus ride to the library these days.If i had the money to buy the book,i would'nt have bothered anyone on the internet with my problems.I apologize if my asking for help has offended anyone,it wont happen again.
  • 585 Answers
If you need detailed instructions with illustrations, go buy yourself a Haynes or Chilton's manual for the car. Or check with your local public library to see if they have the manual you can check out.
Posted on May 23, 2009
Need to know what each fuse under the hood for a
when you remove the fuse cover, the diagram and list is generally posted to the inside of the cover. If you lost the cover, you may try a junk yard and see if you can find a fuse box cover.
Oct 06, 2014 | 1989 Buick Regal
My 1991 Buick regal failed the smog check, issues was failed the Fuel Evaporative Controls Functional. How can I fix it and pass smog check?
The emissions control valve is bad. Get a manual for your car from an auto parts store for the location and removal instructions.
Jun 10, 2014 | 1991 Buick Regal
Where is low pressure port for air conditioner on 99 buick regal
This one took me 30 mins to find, its at the back of the engine at the center of the firewall (below the windsheild ) . This is where the a/c lines go into the car ( evaporator) its hard to see if your tall . Remove the cap and attach your guage . Good luck.
Ps. Fix the leak first
May 04, 2010 | 1999 Buick Regal
I have a 1989 buick park avenue electra and I don't know how to remove the air filter box lid in order to change the air filter. I see no spring clips that are holding it into place.
I had a 1989 Buick Regal, and from what i remember, there were philips head screws, or bolts in the corners of the lid, that when unscrewed, they separated the top from the bottom, thus exposing the filter. And I believe they screw/bolt heads stayed connected to the top lid part.
Totally going on memory here. Hope this helps.
Apr 06, 2010 | 1989 Buick Electra
Where is mass air flow senser on a 1989 buick regal
Hi
Thanks for using FixYa. The BUICK Regal Mass Air Flow sensor is usually installed in the intake air duct between the air filter and the throttle body mounted on the intake manifold. Also check the throttle body for mass air flow sensors location.
On mass air flow sensors with a sense wire, this wire can become contaminated with dust particles. These particles can be removed with automotive solvents that are safe for the use on mass air flow sensors. Before replacing the mass air flow sensor check for air leaks in the connecting air ducts and intake manifold. These leaks can cause similar symptoms as a malfunctioning mass air flow sensor.
Bad or contaminated BUICK Regal Mass Air Flow sensor can possibly cause a wide range of various vehicle drivability problems such as stalling, especially when the engine is cold, misfiring, poor acceleration, etc. In addition, a problem with the Mass Air Flow sensor often causes the "check engine" or "service engine soon" light in the vehicle instrument panel to illuminate.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | 1989 Buick Regal
A/c blows hot air on drivers sde
The actuator door on the driver's side is out of position and needs to be reset. Remove the negative battery cable for 1/2 hour to reset the computer. Start the HVAC system and you should be able to hear the door adjusting itself and cold should come out of the driver's side vent.
Sep 19, 2009 | 1999 Buick Regal
'89 buick regal replaced ECM, 02sens, IAC, MAP sens and throttle position sens and still idles fine but boggs and dies when I touch the gas!!!! PLEASE HELP!!!
have you tested the fuel pressure . should be about 35 lbs while idling and theres also the maf sensor mass air flow
Jun 12, 2009 | 1989 Buick Regal
A/C EVAPORATOR HAS A LEAK .NEED TO REMOVE AND REPLACE
You must remove all refrigent from the ac system using a Approved container for removing ac refrigent it is illeage to release refrigent into the air if you take this to your local garage they can drain this for you for short money. After drained using flare nut wrentches remove the steel lines from the unit unbolt the unit and pull it out. reverse this procedure when finshed and racharge the ac with the correct amount of refrigarent
May 23, 2009 | 1989 Buick Regal
Turn Signal
The turn signal switch most likely needs to be replaced, and yes the steering wheel does have to be removed to make this repair.
Aug 04, 2008 | 1992 Buick Regal
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
