Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Occasionaly the engine shuts off and won't start on JD gx345.
Now it won't start at all. The fuel filter appears to be dry. I replaced the fuel pump. still no fuel in filter. I can remove the fuel line at fuel pump and drain the gas from the tank completely. I have spark from both coils. Replaced plugs & caps. Any ideas
    New Friend:
Check power to the fuel shutoff solenoid .If the solenoid is not working theres a air lock in the fuel line.THE fuel filter will apearto be empty!
Posted on Dec 10, 2013
  • JOE GREEN
    JOE GREEN Jan 18, 2014
    power for shutoff solenoid comes from the key switch
  • JOE GREEN
    Add a Comment just chaged key switch and my tractor runs fine
    President:
  • 957 Answers
If the fuel pump is working correctly then the problem is between the tank and the pump. run a fuel line from the pump to a gas can. If the pump is working it will siphon the fuel into your filter. If the pump is fine then there is blockage, broken fuel line (sucking air), or something blocking the pick up inside the tank.
Posted on May 23, 2009
Out of Diesel
This particular JD engine has an individual fuel pump for each cylinder. The injectors, fuel lines, and pumps are not accessible from outside of the engine. There is a hand primer pump built into the top of the fuel filter. Start by removing the rubber outlet line from the filter base and pump the primer pump until fuel come out of the filter base outlet. Ounce fuel comes out of filter reconnect the line and continue pumping by hand until the pump button feels solid, then crank engine until it starts. This works better if a helper is available to operate the starter while continuing to pump the hand primer. This is normally all that is needed after running out of fuel.
If fuel does not come out of fuel filter base there may foreign material inside of primer pump. Primer pump can be disassembled and cleaned. If fuel comes out of filter, primer pump become feels solid but engine does not start the fuel control rack inside of engine may be sticking in the off position. This may sometimes be overcome by clicking the key switch from off to on rapidly. If not you may have to have your dealer remove the governor cover to free the rack.
Mar 19, 2014 | John Deere 4020 Gas & Diesel Tractor...
Jd gx345 20 hp kawasaki water cooled. turns over will not start Both coils have juice to bath termals at the same time with the key on or off.
Drain fuel completely from tank, fuel line, and carburetor... Change fuel filter, change spark plug(s) add FRESH gas... Not 1 week, month or year old gas... (Can't be contaminated, or mixed with old fuel) there will be a drain screw on the carburetor (at the side of the bowl) You may need some quick start to get the engine to initially start up and keep it running with the spray until the fuel system fills up with fresh fuel and stays started.
Sep 16, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Caterpillar troubleshooting
First thing to try with any diesel that won't start is to do a diesel system bleed. This one should be before the HP fuel rail type so start by bleeding the lift pump, then the fuel filters, then the main injector pump to lines to the injectors and lastly the injectors. Good luck.
Jun 07, 2017 | Ford Cars & Trucks
2007 Mitsubishi galant crank won't start
best thing to do is check for fuel and spark.your vechicle type has fuel filter in gas tank.remove fuel pump by removing rear seat cushion by pulling the seat stopprr near the floor and lift the cushion up.remove the pump inspection cover on the right side of the vechicle.then remove pump harness connector and fuel lines then remove fuel pump with fuel filter.
Jun 01, 2013 | Cars & Trucks
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
1545 jd mower motor stopps and will not start foe 30 minutes new filters and fuel pump
Hi Craig, when it stops check to see if it has lost spark. If so replace the ignition coil If it runs a kohler engine they are a common failure. Regards Phil.
Jun 19, 2012 | Garden
My mower won't start
try running it with the gas cap loose the vent might be plugged
Apr 13, 2012 | Garden
Motor turns over won't start. Cleaned terminals, put in new battery, still won't start. Removed gas cap to vent air on hot day, still won't start. Lights all come on, all electrics appear to...
Your problem may be one of the following:
First check or just replace the fuel filter. Usually located under the car in front of the rear axle, drivers side.
Next, the fuel pump may be worn out. Usually they get loud or stop working (running).
Next, check the fuel pressure regulator. Usually located on the front fuel rail, drivers side.
Is the vacuum line attached? Not leaking or rotted?
Also, do you smell a strong fuel odor when it won't start? May be one or more stuck-open injectors, or the coil pack is bad.
Checking these in the order listed will more than likely fix your problem.
The clicking noise indicates the battery can no longer run the starter, which also means the fuel pump won't run either.
It could be a fuel issue. How old is the fuel filter? Can you hear the pump run for a few seconds when you turn the key on? Try turning the key to ON without trying to start engine three times waiting for the pump to stop running each time. Then try to start the engine. If it starts, Its a form of Vapor lock caused by the extreme heat we have had lately, and a weak fuel pump.
If none of this works, try a new fuel filter first. From there have someone check the fuel pressure regulator and then the pump. If you are in need of a new pump, take my word for it and spend the money to get one from a Dealer, and not from your favorite parts store. Most parts store parts are made in China and they are JUNK.
Aug 28, 2011 | 1997 Chevrolet Blazer
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
1,353 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
