Question about Vizio VX37L Television
Sudden no signal on digital channels on a Vizio VX37L
I've been getting many, not all, digital channels fine on my Vizio VX37L by just plugging the wall cable in.  I decided to run a channel search to see if I could get more channels.  After the search, I was only getting the regular channels.  When I land on a HD channel, it says no signal.
I have found nothing in the booklet on this, nor is there anything on the menu to choose digital signal.
Anyone know how to resolve this?
  • 2 more comments
  • ssrizkalla May 23, 2009
    it's just the cable from the building.  i guess it serves as an antenna, but i do get some cable channels without subscribing to cable.
    but it was there, fully.  until i did the channel auto search which seemed to kill it.
    i was getting a signal, fully, until I ran an auto search for channels.
  • shawn rogge May 11, 2010
    whats on the other end of the cable,antenna or cable tv?
    Sergeant:
  • 231 Answers
That may not be correct. You would not lose all your digital channels. Vizio has an un-addressed problem with losing digital stations. Multiple threads are posted due to this problem, which is why I am on this site. I have lost all digital stations on CATV connection. The Toshiba set in the next room is getting over 150 DTV channels, the Vizio, only analog. Zero Digital.
Posted on Jan 05, 2010
Same problem here
Posted on Apr 03, 2010
  • vinnirules Jul 19, 2011
    I have same issue with my 42 in Vizio.. scan no longer finds digital stations even though plugged into CATV. is there a resolution?
  • haydenshoney
    haydenshoney Aug 25, 2012
    I also am having this problem, have you found an answer yet?
  • 92 Answers
Thats the problem,you need a stronger signal, if theres no antenna on the roof your not going to get much,digital is either there or not,no in between
Posted on May 23, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: Vizio TV says no signal on digital channels
add each chanel manually
Posted on May 30, 2009
How do i make my vizio vx37l recive high definition antena signal
Go into menu and find TV input area--- change from cable to antenna
Mar 03, 2015 | Vizio Televison & Video
32in Vizio getting no channels
You have to go to your menu screen and change the settings from antenna to cable that should take care of it, and should be able to do a auto scan to load channel memory
Mar 26, 2013 | Vizio VX37L Television
My vizio tv,VX37LHDTV10A darkened and shows shadows in the back ground from previous channel. Do i need to replace the back light inverter master or the main unit part?
This may work for you. My Vizio went black except for the blue channel rectangle in upper right corner; I couldn't change the channels or power off. I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. It works fine now.
Mar 30, 2010 | Vizio VX37L Television
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Sep 30, 2009 | Vizio VX37L Television
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
Black screen on digital channel on my vizio
I had the same problem. Check out my solution by viewing the subject titled Vizio 37L suddenly stopped getting all digital... Hope it helps!
Jun 20, 2009 | Vizio VX37L Television
Vizio 37L suddenly stopped getting all digital channels
I had the same problem with my 42" vizio. Was working fine for about a year and a half, then a month after all stations went digital, I couldn't see any digital channels and it wouldn't scan for digital signals
This is a strange go around, but it worked for me. . Tried unplugging, pushing power button for two minutes... did everything the forums suggest, with no resolve. But, here's what DID work for me. Trust me, it sounds strange, but it continues to work (and, yes... it's not a permanent fix... the channels still go out once in a while, but I can always get them back now)
Use your Vizio remote control. Turn your TV on. Press the "input" button until you get to "RGB", which is what you would connect a computer to. Make sure no computer is connected, or it's at least off if it is connected. When you get to RGB, you'll see a message that says "No Signal". After about 5 seconds, the TV will enter a sleep mode and seem as if it has turned off (orange Vizio logo). Once it completes it's little sleep cycle and "clicks" off, wait a few seconds and hit the input button again. It'll go to the next menu item. Keep clicking input until you're back on "TV", and VUALA! The channels are back!
I accidentally figured this out when trying to troubleshoot, but I'm glad I did. Didn't want to dishout $250 to get it fixed. Let us know if it works for you too!
Jun 15, 2009 | Vizio VX37L Television
Vizio vx37l green/red/blue sparkles
Call Vizio tech support and start a case. i am having the same issues with mine and i have sent it back. they will be replacing it this time.
Jan 12, 2008 | Vizio L37 Television
Vizio VX37L Television Logo
2,479 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
