my wash cycle wont start. The door wont lock, so the cycle wont start. It worked fine the last time I used it. my wash cycle wont start. The door wont lock, so the cycle wont start. It worked fine the last time I used it.
You can't post conmments that contain an email address.
sorry its the clutch and trasmission its going out either repair or replace the washer my wifes washer started doing the same thing somedays it did fine and others times started squeaking.
Have you checked the filter? if it is blocked the machine will know it has not emptied and will do odd cycles but not work, a google search will reveal the location of the filter, except my new maytag that has none so a turn over and dismantle it the only option, after bailing,
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
With the Door Lock display on (which is what the red key indicates), are you able to open and close the door?
If so, you probably have a defective door lock assembly. Try unplugging your machine for a couple of minutes and plug it back in to see if it resets itself.
You dont say how big this rug is, but I am guessing its not big enough to spreadevenly around the machine. The machine senses an imbalance and willo not spin or failos to spin at a rate that would rekove the water. Try adding some balance to the drum with another object that will evenly spread the load to see if that helops to get rid of the sopping water. BTW any pictures of you whipping the rug around in the backyard? That should make for Utube fame!
