Question about JVC AV-48WP30 48" Rear Projection Television
Picture bowed I replaced the Convergenc IC chips the color is good now but the picture is still curved on the top and bottom
  • 1 more comment
  • help830 Oct 22, 2007
    I have a Phillips 60 inch rear projection TV and I changed the convergance IC's and the color is great but the picture stayed bowed on top and bottom. What do I do??
  • help830 Oct 25, 2007
    The Television is a Phillips model # 60PP920217 and I went into convergence menu and adjusted the colors but no way to adjust the vertical.
    We adjusted the color and the color looks good but the picture is still bowed on the bottom and the top like an hour glass laying down.  Could the IC's have been faulty??  How can you tell if the resisors or bad?
  • 105 Answers
With tv power on press (062597 exit) on the remote to enter convergence mode
Posted on Oct 24, 2007
  • Troy Shull
    Troy Shull Oct 25, 2007
    if you cant move the color up or down then you will need to fix the convergence circuit. usually the stk ics fail (stk 392-120) you will find these mounted on a large heatsink located on the middle board. also check the sorounding resistor and fuses.
  • Troy Shull
    for the resistors just use a cotinuity tester and make sure none of them have opened. if you enter service mode and do convergence you should be able to move all thre colors left, right, up, and down. if you cant then you still have a problem in the circuit.
  • 363 Answers
This is called vertical pincushion IMHO.
With a bit of luck you should be able to adjust this from the service menu.
Access the service mode: set SLEEP TIMER to 0 MIN.
While this is still displayed, simultaneously push DISPLAY and
VIDEO STATUS.
Posted on Oct 19, 2007
  • Martin B
    Martin B Oct 22, 2007
    Ahh it's a Phillips 60" now. The model number please?
Picture curveing down in the middle from the top and curveing up in the middle from the bottom. It also has double and triple colors/images.
your covergence curcitshave failed . there is a high chance that the stk- chips will need to be replaced. at our shop such a repair averages about 150. there may also be some micro fuses that will blow when these chips blow
Oct 22, 2010 | Sony KP-51WS500 51" Rear Projection...
Color is wacked - too yellow, blue half moon at top of screen
WS-48315 uses two of the STK-394-250 convergence IC chips---if blue or red will not adjust both chips along with any bad protect resistors around them need to be replaced and the set adjusted.
Both chips can be purchased for under 30 dollars on Ebay---this may not be a job for a do it yourself person--requires soldering skills and ability to get at the chips and un-solder them and replace them.
This set was first made in 2004---if you cannot do the repair yourself--shop around your area---most shops charge at least 300 for this repair and some will not do it in your home.
You have to decide first if you are able to do it or if not if you want to spend money to get it fixed.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE let me know---I am here to help.
REGARDS, SD TECH
Oct 27, 2009 | Mitsubishi WS-48315 48" Rear Projection...
Curved in at top and bottom and rainbow colors on bottom
REPLACE ALL STK?????? CONVERGENCE AMP IC'S & CHECK RESISTORS FOR THAT CIRCIUT
Apr 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
The picture is drawn in from the sides
this problem we cal vertical fault..cause by capasitor is not in good condition at vertical area or loose solder at the vertical ic
Dec 08, 2008 | RCA F35673MB 35" TV
The tv you sold me
pin cushion is gone.
time to get a new one.
don't try to fix it. not worth the time of the money.
Sep 24, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Sony kp-48v75 picture arcs at top and bottom
Convergenc IC proble look for and replace all Stk392-XXX
Dec 03, 2007 | Sony KP-48V75 48" Rear Projection...
Seperated colors
this is a common problem you have bad solder connections on the convergenc ics solder them back if this does not fix the problem then replace them k
Nov 03, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Uh oh... the colors are curved and wacky
replace the amplifier IC chips for the convergence.  part # stk392-???  could be from 040 to 120..  90% chance that'll fix it.
Oct 08, 2007 | Panasonic PT-47WX49 47" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
70 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
