Question about Radio Communications
The green light in the kenwood radio is staying on even if it is not communicating
Need wiring diagram for Kenwood KDC-X679 CD receiver for my 1997 Chevy truck
The manual for the Kenwood Excelon KDC-X679 has the wiring diagram for the connections to the car/truck on page 33. Crutchfield has the manual on the product page: http://www.crutchfield.com/S-FpCU7SY0yQm/p_113KDCX679/Kenwood-Excelon-KDC-X679.html . (Click on the Details tab.) The direct link to the manual is http://pdf.crutchfieldonline.com/ImageBank/v20050828082600/Manuals/113/113KDCX679.PDF .
Kenwood also has the manual on their support page: http://manual.kenwood.com/en_contents/search/ . Just enter the model number. On this site, you can find the manual is several languages. The direct link to the English version of the manual is http://manual.kenwood.com/files/B64-2764-00.pdf .
I hope this helps.
Jan 30, 2016 | Kenwood Car Audio & Video
Just bought a new Kenwood 2400 to add to the other 2300 radios and I can't get them to communicate even though they are both on channel 1 which should be the same frequency! Help!
The 2300 is Vhf and the 2400 is Uhf. They cannot talk to each other. Not a programming issue, the wrong radio band and it cannot be changed.
Jul 14, 2015 | Kenwood Radio Communications
Trying to find a wiring diagram to install my kenwood kdc-mp342u into my 2001 grand am. any ideas?
Please let me know if you have any questions, and thanks for using FixYa.
2001 Pontiac Grand Am Car Audio Wiring Diagram kenwood kdc-mp342u
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: none
Run a wire to the fusebox for switched power. red
a 14 gauge wire will do--use a 15 amp fuse
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Gray (tape this wire off) none
Car Stereo Dimmer Wire: Brown (tape this wire off) none
Car Stereo Amp Trigger Wire: Pink blue
Left Front Speaker Positive Wire (+): Tan white
Left Front Speaker Negative Wire (-): Gray white/black
Right Front Speaker Positive Wire (+): Light Green gray
Right Front Speaker Negative Wire (-): Dark Green gray/black
Left Rear Speaker Positive Wire (+): Brown green
Left Rear Speaker Negative Wire (-): Yellow green/black
Right Rear Speaker Positive Wire (+): Dark Blue purple
Right Rear Speaker Negative Wire (-): Light Blue purple/black
Amplifier Mounted behind trim in the left side of the trunk.
May 19, 2011 | Kenwood Car Audio & Video
My kenwood light is red it turn green 4 a slpit second n turn bac red n want play my subs need help how to fix it
UNHOOK YOUR SPEAKER WIRES FROM AMP/IF THE GREEN LIGHT STAYS ON IT IS ONE OF
YOUR SPEAKERS.
Dec 21, 2010 | Kenwood Car Audio & Video
I have a green signal light that keeps blinking? My radio will not reset when I try to reset it.
Accirding to the manual, which can be found at,
http://inform3.kenwoodusa.com/Manuals/USA_LMR/TK-2200%203200_B62-1791-00.pdf,
To start scanning, press the Scan key.
• The LED indicator flashes green and scanning starts from the
current channel and ascends through the channel numbers.
• When a signal is detected on a channel and the QT/ DQT
matches, scan pauses at that channel and the LED indicator
lights green.
• When the signal is no longer present, scanning continues after 3
seconds (default).
As far as the radio not resetting, I would suggest contacting Kenwood:
By Phone/Fax:
Land Mobile & Business Radio Divisions
Phone: (678) 474-4700
Fax: (678) 474-4730
Hope this helps,
tkhusa420
Oct 03, 2009 | Kenwood ProTalk TK-3200U8P (8 Channels)...
Tk3200
The squelch circuit is open.
May 17, 2008 | Kenwood Radio TK2200 TK3200 Compatible...
Kenwood spares
Hello samisskip,
To get replacement jack covers you are very likely going to need to contact the manufacturer. You can access the Kenwood Communications website at
http://www.kenwoodusa.com/Communications.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 11, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
I need some speaker / microphone jack covers for kenwood TK3101 radios, anyone know where i can get some?
Hello samisskip,
Best Regards,
Agent Ken
Go Ahead. Use Us.
Green light blinks
On my two channel radio a blinking green light means that it is scanning between the two channels. I can turn off the scanning and the light stops blinking.
Sep 21, 2007 | Kenwood Radio TK2200 TK3200 Compatible...
Radio Communications Logo
51 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
