Question about Alpine CDA-9825 CD Player
Alpine CDA-9825 CD Player won't work at all.
I just got this 1993 Honda Civic Si hatchback from my dad. It's face to the stereo has been rarely taken off if not never for like 2 years. I just started taking it off about a day or two ago so nobody steals it. Earlier the face wouldn't light up and it was on 1 radio station and I could only do the volume. We took the face off and there's a reset button. I clicked it in and now nothing is working on the thing. What could be wrong with this?
  • blueextc3221
    blueextc3221 May 11, 2010
    use an eraser on the metal contacts on the radio and back of faceplate and re-try.
Duncan
  • 218 Answers
SOURCE: alpine head unit CDA-9855R
Yes, I'm sure Alpine will sell you another face but there is still the option of repairing the broken face at a good repair shop. Of course getting a new face is the easiest (read most expensive) way to get you going again.
Posted on Jun 10, 2007
ampman
  • 98 Answers
SOURCE: how to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Posted on Aug 21, 2007
SOURCE: Alpine Ipod/Stereo Error 1 message
Sorry but the ipod should never "die" when it's plugged in. I own this system and have encountered the same problem. The ipod should be continuously charging if plugged in, therefore it should never run out of juice.
Things I've been told to do f rom Alpine themselves:
-Get latest version of ipod software from itunes
-Plug ipod back into unit (via cord) with car turned off
-hold the center button and play button until ipod resets itself
-take off alpine face
-press the little button behind face to reset unit
I have done this with some success. The problem returned once in a while, however, for some reason after doing the process listed again a few months back, I've not had the error.
Posted on Nov 12, 2007
  • 11 Answers
SOURCE: ALPINE-CDA-9854R Radio works but the panel won't light up
the counters on radios with detachable faces go bad forum coronation sum times try a small nail file on them to clean it off
Posted on Dec 15, 2007
c renner
  • 43 Answers
SOURCE: radio has sound but not the CD player or iPod
Your amp is not turning on - what you should do is connect the "blue/white - remote turn-on lead" to whatever wire you have the "blue - power antenna" output from the Alpine connected to now. That should solve your problem.
Posted on Mar 08, 2008
When I turn Cd player or car off then back on the Cd player no longer has any of my settings saved
its because your yellow wire isnt connected straight to the battery it would probably be connected to switched connect it to the battery and it will fix the prob
rate pls
Aug 17, 2010 | Alpine CDA-9825 CD Player
Stereo sounds stops but stereo stays on
This is due to a short in one of the speakers Or a blown speaker making it short out and stereo will stopped outputting any sound to prevent damage to the stereo.
Jul 30, 2010 | Alpine CDA-9825 CD Player
I am hooking up the stereo and I know I have power coming to the wires cause the black and yellow ones spark but when I hook them to the stereo I don't get any power
The yellow wire is the constant wire, you need to find the battery + wire which will be red and hooked that to your deck, the red wire is the main 12v wire and the yellow wire is there just to use a little bit of power to keep the memory i yur deck, i.e. the time, cd position stuff like that
May 19, 2010 | Alpine CDA-9825 CD Player
I need to know what cable goes to the fm system
there is no colored cable for the fm system.
There should be a wire that comes out of your car to the back of your cd player.
all you do is hook that one up to the antenna connector on the back of your new cd player
Mar 18, 2010 | Alpine CDA-9825 CD Player
Alpine cda-9855r with no display
when mine does that it is down to the connection of the face to the head unit, push it firmer or remove and replace. it may be that the connection is worn.
Sep 15, 2009 | Alpine CDA-9855 CD Player
Problems with amp or stereo
check out www.installer.com
this site has your stereo's wire diagram.
The amp wires only go to the rear output (rca jacks on back of cd player)
It wont work right if it is connected to the front outputs on the back of cd player
Jan 16, 2009 | Alpine CDA-9856 CD Player
Volume problem with the AUX input using iPod
Do you have the ipod turned up too? Whats happening is the alpine is getting to low of a foltage signal.
Jul 30, 2008 | Alpine CDA-9825 CD Player
Alpine CDA-9825 CD Player Logo
155 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
