Question about Melissa And Doug Big Rig Trucks
Crusie control on 03 mack vision not working
I hit a bump in the road and the cruise control shut off and the engine brake also in not working. please help. this is a big truck and a little truck a semi ok laura
    Problem Solver:
  • 19 Answers
It is ur cluth switch that is not letting ur cruise or jake brake works
Posted on Aug 15, 2010
Intermittent Cruise Control Issue - cuts out when small bump in road is hit and may or may not re-engage after that.
Check the wire connector that plugs into the cruise control under the hood. Sounds like a loose connection. Remove the and reinsert the wire connector several times to make a better connection. Stepping on the brake pedal disengages the cruise control by a switch on the brake pedal, not the computer.
Jan 09, 2016 | 2004 Buick Rendezvous
Crusie control doesn't work
The brake light switch (which also controls the cruise control) was not adjusted correctly. Also the stop pad may need to be replaced and the part is available or a penny can be taped or glued in place for a temporary fix.
Apr 30, 2014 | 1995 Acura Legend
Crusie control does not work on 2011 gmc sierra 1500 and I've already replaced the switch?
If the switch is replaced,then it can be wiring issue or faulty cruise control board.But as the switch is replaced,get the voltage at the switch tested to confirm the switch is actually receiving voltage.If no voltage received at switch power supply wire then ,apply external 12 volt power to the cruise control switch wire and then see if cruise control comes ON.If yes,then you know wiring is issue.
On this case, to troubleshoot this problem, there are solved help links. Click the link directly and refer the details to solve this problem yourself, with help of diagrams: ------
Ford ranger cruise control not working? http://technoanswers.blogspot.in/2012/02/ford-ranger-cruise-control-not-working.html
Horn and Cruise control quit working?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working.html
Horn and cruise control not working on Plymouth Grand Voyager?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-not-working-on.html
Horn and Cruise control quit working on 2003 Jaguar S-Type?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500
http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger?
http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working?
http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
1996 Ford Explorer: Cruise Control Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/1996-ford-explorer-cruise-control.html
These will help.
Thanks.
Nov 28, 2012 | GMC Cars & Trucks
Does brake light switch affect cruise control?
Yes. The brake light switch has to be in good condition because it is one way to disable the cruise when driving.
Jul 24, 2012 | 2004 Chevrolet Malibu
Problem with cruise on 2003 E350 7.3L engine
Hello! The Parking Brake Switch is defective...It is not adjustable ...it is held in pace by a locator pin and a bolt and is located on the brake controller.
wire colors are Light Green/Red and Black...The contacts are spring loaded and are closing due to vibration...If the bruise control is set and you nit a bump the contacts will close...If cruise is set it will clear it just as if you hit the brake...See picture below...Guru...saailer
MOTORCRAFT Part # SW2217 Cost =<$15
Nov 09, 2011 | Cars & Trucks
I have a 05 Ultra classic where once the cruise control is set it deactivates when I hit any kind of bump in the road. After much tinkering I have found that any and I mean any slight movement in the front...
Sounds like the front brake assy. on the handle bar was removed without the card board insert installed between the front break lever and the little piston which can damage it and cause the front brake switch not to work right as the piston in the handle assy. won,t slide back and forth when the lever is moved in and out
May 25, 2011 | 2003 Harley Davidson FLHTCUI Electra Glide...
03 z71 tahoe wiggs out when u hit a bump abs light brake light service brake system in dash comes on also reduced engine power comes on it shuts of but starts back on its on and door locks cycle but runs...
I have had the EXACT same problem with my 03 Chevy Tahoe!!! I have yet to find out the solution!? I cleaned all my grounds and changed my rear speed sensor along with bench tested my alternator! Have you found the problem? I would be very grateful if you could hit me back with an answer!! Thanks
Aug 31, 2009 | 2003 Chevrolet Tahoe
CRUSIE CONTROL DONT WORK 1993 LS 400
check brake fluid level.if to low cruise will not work. also check all fuses.
Jan 07, 2009 | 1993 Lexus Ls 400
Melissa And Doug Big Rig Trucks Logo
188 people viewed this question
Top Melissa And Doug Toys Experts
Jennifer Rock
Jennifer Rock
Linda Gentile
Tom Chichester
Are you a Melissa And Doug Toy Expert? Answer questions, earn points and help others
