Question about Dell Latitude L400 Notebook
LCD dim. Dell Latitude LCD screen is dim (no backlight)but I can see MS Windows screen using a flashlight. Replaced inverter and monitor, but same result. When external monitor connected external works fine. Help!
  • 585 Answers
If you have replaced the screen and the inverter, about the only thing left is the flexible cable from the monitor to the video card. I take it that the Fn+F8 makes no difference?
Posted on May 23, 2009
Dull laptop screen back light
You may have a faulty CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Dec 30, 2009 | Dell Latitude C610 Notebook
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
D600 Latitude laptop - LCD showing ghost/dim images
Connect an external monitor to your laptop and power it up, if you seethe normal Windows images then the video card and laptop is OK and theproblem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dimimage and/or dark display on the laptop's LCD screen indicates a faultyLCD backlight and it could be the inverter that supplies high voltageto the CCFL lamp or it is the CCLF lamp is nearly burnt out or burntout, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
Thank you Sir, Have a nice day.
Sep 19, 2009 | Dell Latitude D600 Notebook
Display Problems
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Jul 02, 2009 | Dell Latitude 100L Notebook
Won't see clear image in display
Check out
www.lcdparts.net
Jun 28, 2009 | Dell Latitude D600 Notebook
Dell Inspiron B130 was black when turned on. Holding flashlight to screen, could see desktop and all icons. Was able to open programs, etc., while looking with flashlight. Replaced LCD Inverter listed for...
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
May 03, 2009 | Dell Inspiron B130 Notebook
Laptop screen Problem
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 11, 2009 | Dell Latitude D810 PC Notebook
Dim Screen when Power is Unpluged
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Mar 27, 2009 | Dell XPS M1330 Notebook
Replaced screen computer comes on, but screen stays black.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the backlight.
Mar 22, 2009 | Dell Latitude D600 Notebook
Dell latitude D600 display blacks out, showing just a ghost image
Mar 21, 2009 | Dell Latitude D600 Notebook
Dell Latitude L400 Notebook Logo
350 people viewed this question
Alun Cox
