Question about kawasaki Full Suspension Mountain Bike Men
Kawasaki mule heat light staying on
After I replaced the water hose and filled with water the heat light keeps coming on I don't think the water is circulating
    President:
  • 272 Answers
Replace the impeller in your water pump. It's an easy job and needs to be done every 2 or 3 years depending on use. Why they put a rubber impeller in these I do not know. Your local Kawasaki dealer will be able to help you with the part.
Posted on May 23, 2009
Kawasaki mule 2500 keeps running temp
go to TRACTORBYNET.COM enter OVERHEATING MULE in the question block. there is a forum on this problem, and may as well register.
Oct 05, 2015 | kawasaki Motorcycles
2011 Kawasaki Mule: Loses power when it warms up. even in cold weather. further you push the gas pedal less power it has.
If you have a vent hose coming out of your gas cap make sure it is not kinked. A kink in the hose will cause a vacuum in the gas tank and very slow gas delivery to engine, which would become apparent at higher engine rpms including after warm-up.
Mar 17, 2014 | kawasaki 2011 Mule 610 4x4 XC
Kawasaki mule 2012 4010 aftr running few minutes temp light will start flashing and efi light comes on then rpms just at idle
the thermastat is probly stuck shut replace it with a new one if problem still persist you may have engine damage aka cracked head ect
Feb 08, 2014 | Vehicle Parts & Accessories
Kawasaki Mule bleeding coolant causing problems
Its probably the head gaskets. When you do the compression test its not running and the holes in the gasket could seal up. When it gets hot a hole could appear in the gasket or even a crack in the head.
Its clear from the rising coolant levels that something is putting pressure into the coolant, do the bubbles in the coolant smell of fuel?
Dec 22, 2013 | kawasaki 2005 Mule 3010 Trans 4x4
Kawasaki Mule Coolant Overflowing
I would be having a compression test done to confirm that there is no head gasket or cracked head problems as what you describe can only be coming from excess pressure in the coolant system from compression pressure.
Dec 21, 2013 | Cars & Trucks
Why does my Kawasaki mule 3010 stall and then won't start for about 10 minutes
Have your fuel pump checked. The wires on mine were melting due to the regulator attached the pump being bad so when the mule would first start it would run fine until it warmed up and then no gas once the wires warmed up. Don't buy the Kawasaki replacement unless you want to pay $300 or more for the part (They are crazy over-priced on parts) and labor. Got a 3rd party pump for $50 and had it replaced for one hours labor and we are good to go. Worse case next time around I buy another $50 pump and replace it myself
Aug 14, 2012 | kawasaki Motorcycles
Over heating of car radiator
First of all see the fan is working,this probably the main cause,secondly it can be the water pump not working.I give a tips,to know if the the pump is working properly,when the engine is cold,you take out the hose from the radiator,the upper one,when doing that your radiator must be full of water,now let someone start the engine and you stay in front of the bonnet ,when already start the engine ,see from the the hose that you have taken out if water is coming out well,accelerate a little more see if the water come out rapidly and constantly,be careful not to let the radiator empty keep it with water keep filling it by using a water hose,if the water pump is not pumping enough that the cause of over heating.
Jan 08, 2010 | 1990 Nissan Sentra
I have a Kawasaki Mule 3000. It is hard to keep
take the spring off the screw and use teflon tape so you can adjust the screw further
Sep 11, 2009 | kawasaki Sport & Outdoor - Others
1994 Honda Civic LX\overheating within 2 mile drive
Remove and raise upper hose at thermostat end and remove lower rad hose.
Fill rad with a hose and watch for flow from bottom rad hose and/ or bottom rad hose connecton.......water should fall though rad easily.
Honda rads are cheap.....any restriction....replace rad.
Remove thermostat....fill thermostat housing with hose and watch for water flow at bottom rad hose.
Flush good.
Remove heater hoses.......flush back and forth until a good flow is present "With heater control set to hot" if no or poor flow....replace heater core.
Stop leak can plug everything.
Also.......not likely causing over heating....but ....at your mileage,if you do not know if the timing belt has been changed.....CHANGE IT NOW!
Water pump is optional at this mileage.
Aug 23, 2009 | 1998 Honda Civic
Hose keeps coming off icemaker on ge 25 cuft side by side refrigerator.
Defrosted the freezer section and also used a hairdryer to clear out to tube. I left the fill line full of water and heated the water with the hairdryer then forced the water through into the icemaker. So far the hose stayed on and we are making ice again.
May 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
kawasaki Full Suspension Mountain Bike Men Logo
322 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
