Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas
Won't lite, checked water flow and gas both good
Laars lite with the old manual control panal not digital. Will not lite, or start ignition process. Water flow is good, natural gas is flowing. Is there a reset for the ignition system?
Could be the pressure switch.
Posted on May 24, 2009
Jandy LXi gas heater error message "ignition control failed
if ignitor is glowing try changing position of the shutter 1/2 to 3/4 open should lite
Dec 22, 2012 | Jandy Laars LX Pool Heater / 250,000 BTU /...
Why won't my Laars Lite 400000 heater light?
should be 24 volts ac tyo the brown and yellow wires to the gas valve at start up or when you hear click
Jun 20, 2012 | Teledyne Laars Laars Lite2 Heater 400000...
We have a Laars Lite 2 which will fire and run for about 5 minutes then shut down. We changed the 135 and 150 limits as we noted a drop from 24 to 14.6 V. It appears to me that the unit is over heating. We...
make sure correct gas pressure if too low it will soot up and overheat sounds like transformer is going should be 24 volts if not pressure switch wont stay on also check the manual bypass by plumbing side if spring is bad water will not go through the heater correctly
Jul 02, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
How to test an ignition assembly board for ld/125 laars lite 2 before replacing it.
this may tell me you dont know if the ignition control is not working. see the owner manual at jandy.com
Aug 26, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater ignites but stops after 2 or 3 seconds
Mine did this and after increasing water flow it stayed on. Service guy said it needs to see a good flow rate to stay on.??? Worked for mine,.
Jul 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 Heaters starts up (ignites) and shuts down in 2 secs
usually indicates a flame sensing problem. remove sensor and clean with steel wool .
Jun 23, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
MY Teledyne Laars is 20 year old +
check pressure switch (looks like space shuttle copper wire one side 2 wires other side) need 24 volts ac both sides if not need new
Dec 18, 2008 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas  Logo
674 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
