Question about GE DBL333EA Electric Dryer
Belt installation how do you install the belt on a ge dryer, cannot figure out how to make tensioner pully work
  • fred2223 Jun 08, 2009
    thank you, just took seconds after your advice. fred2223
    President:
  • 1,136 Answers
HI, Looking at the idler assembly from the back, move the idler wheel to the left (spring loaded).
Slip the belt on the motor pulley with ribs touching pulley. Now let the idler pulley rest againdt the back side of the belt.
I hope this helps you.
Please let me know if I can help further.
Vic
Posted on May 23, 2009
  • Victor
    Victor Jun 08, 2009
    You are welcome
How to put belt back on drum on my dryer
You have to take the back off of the dryer and see the motor pully and the idler pully. slip the belt around the drum, around the mototr pully and usind a flat blade putty knife, work the belt over the idler pully so that it puts tension on the belt. you may have to loosen the idler pully housing bolts, but try it first with working it over the idler as that was set for optimum tension.
Feb 04, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
The belt for the dryer is not in place and the dryer is not longer spinning. how would i fix that? There is also a piece with a wheel on it that i cannot figure out where it goes but looks as though it is...
Look up "Tension Pully & Belt Diagram" on internet for your dryer on google or Dogpile. You should be able to find how to
put the Tension Pully back where it belongs & how to thread the belt through it and back on to the motor drive shaft. Check different sites for the right picture for your dryer. Here's a picture to get you started. Good luck,
Sep 13, 2010 | Kenmore 500 6952 Dryer
I cannot find the manual for my DPSB3620 GE Profile Dryer. It turns on but nothing moves and I can't seem to be able to open the back
the only panel in the back that can be removed is at the bottom where the vent hose hooks up....the way to get to the belt is. remove the screws where the lint screen pulls out ...pop the top section of the dryer...their are 2 clips in the seam at the top of the dryer ....about 2 inches from the edge use a flash light to see them ...use a screw driver ....go between the horizontal seam at the top to pop ..then their are 4 screws holding the front of the dryer.2 at the top .2 at the bottom ..only loosen bottom screws do not remove them ..then the front of the dryer with the door can be removed ..now you can install the new belt ...remove the lower panel in the back to see motor ...the drum pully //tensioner this is where you put the belt on the pully ..let me know ..if you need more help....good luck../joe
Aug 29, 2010 | GE Dryers
The idler pulley on an older GE dryer does not tension the belt. The idler pulley is mounted on a spring rod, but the rod's neutral position does not tension the belt. The rod is attached to the bottom of...
Do not bend the rod you are not threading the belt right I had the same problem with one. Try searching the internet for how to thread the belt on a GE dryer. It has to go around the pullys a different way. Hope this helps.
Jun 04, 2009 | Kenmore 60172 Electric Commercial Dryer
Tumble dryer ,creda tcr 13
hello dave to do this you'll have to take the front panel off so you can pull the tumbler out so you can get to your pully and tensioner on the bottom on the dryer,loop the belt on the pully and keep tension on it while you slip the tumbler back in now loop the belt around the tumbler and after the tumber is sitting on your glides spin the tumbler till the belt is in place,if you can have somebody help you its easyer putting the tumbler back in with 2 people while keeping the belt on the pully on the bottom of the dryer. any other problems or questions let me know i've dont mine about 6 months age its a little pain in the **** but not inpossable
Apr 09, 2009 | Dryers
Dryer won't tumble
are you sure you installed the belt properly ? a lot of dryers have an idler pully that the belt has to go through to create the correct amount of tension. that's about all there is to check
Jan 23, 2009 | Whirlpool GEQ9800P Electric Dryer
Install dryer belt
more information needed to specifcally match the model
however dryers are all similar so
generically, UNPLUG dryer
A:top mounted lint filter (kenmore maytag(New))
  • remove lint filter
  • remove screws in lint filter housing
  • with putty knife or other flat blade depress lock tabs at front corners of top body panel
  • tilt top panel up
  • remove screws 1/3 way down each side, remove door switch wires
  • remove front panel set aside
B:dryers with screws at bottom of front panel (maytag speedqueen)
  • remove screws from bottom of front panel
  • tilt front panel up
  • remove door switch wires
All
  • pull drum forward & out
  • examine drum felts, rollers, and slides for wear replace if worn
  • wrap new belt round drum at old wear marks
  • insert drum
  • wrap belt round motor pully
  • pull tensioner pulley hard to end of travel against spring
  • wrap belt round tensioner pulley
  • release tensioner
reassemble
Oct 19, 2008 | GE Dryers
We are trying to install a dryer belt onto a GE older moder dryer and can't figure it out. The model no is GDX8060RT429
Hi. thanks for the question. remove the top. lift , remove front. slide belt on drum .clean all lint. reinstall front and top. pull away from wall. remove back panel. motor on right idler pulley on left bring the belt down to push idler down ,to give the belt tension .put belt around motor pulley . thanks the appliance doc
Oct 02, 2008 | Dryers
Fixing a gas dryer belt
That I believe is an older model GE with the idler bar instead of the short bar. I believe there is also a rear panel that you can remove to gain access to it. I dont remember for sure if it keeps tension up or down. Loop your belt around the motor pully, then find out which way it keeps tension on the belt, then loop the belt around the idler pully and release so that it keep tension on the belt itself. Let me know if you need further information.
Feb 06, 2008 | Dryers
GE DBL333EA Electric Dryer Logo
219 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
