Can't burn cd in my Preclick Picture Software -no drives availabl
Burning cd from Preclick shows error that there are no drives available I was able to do this before not sure what happened though, it plays dvd and cd but won't burn from Preclick thanks
  • ogiereynoso1 May 11, 2010
    Try using NERO burner. I personally use and i am not having any hard time like you do. :) hope this help.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 194 Answers
R u able burn the cds normally if yes then go to device manager and uninstal the cd or dcd drive and restart the system and if possible install nero
Posted on Aug 19, 2009
Trying to burn a movie from a new burner by samsung 22x 768564 dvd, but the green line doesn't keep up with the timer, i let 1 movie burn for 12 hours on timer and all it did was encode, didn't...
should not take 12 hrs to burn
does it burn data cd/dvd or audio cd/dvd's ?
you might have to burn it as an ISO image
this might be because you have not selected the option to burn a dvd movie you might have selected another option ie:burn data audio or your burning software does not support movie dvd burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Sep 25, 2011 | Samsung Computers & Internet
Whenever I try to burn a cd in my DVD ram a message shows up saying it is not accessible, Incorrect function.? What do I do? ive tried to disable and enable the drive then reboot the sys., still the same...
try running the fix-tool provided by Microsoft on this web page
http://support.microsoft.com/gp/cd_dvd_drive_problems
If that fails then my suspicion is that either
1) the drive has failed
or more likely
2) because you don't have any DVD burning software, windows can't understand the blank DVD-RW disk. Thas basic packet-burning software installed with XP CANNOT write to DVD disks.
However there is a bit more to it than that - the Microsoft CD burning software (which is a cut down Roxio product) cannot co-exist with any other packet burning software (e.g. DLA, In-CD or simuilar) so if one of those is installed you have to DISABLE the MS CD burning capability on the drive settings tab. Even worse, Internet Explorer 8 is not compatible with DLA - which is included in quite a few CD/DVD suites including many of the later Roxio versions
My advice would be
1) un-install any CD or DVD burning software on the machine
2) disable the MS CD burning
3) run that Microsoft patch
4) Install some DVD burning software but DON'T install the packet writing software part of it
Note that after installing that patch you may also have to reinstall any DVD playing software
Nov 07, 2010 | Computers & Internet
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
How do I format a Cd to burn pictures on it
You don't format CD's. Simply drag and drop.
Nov 05, 2009 | Dell Inspiron 1501 Notebook
I want to burn photos onto a CD. The box I have
You can burn any type of file on a dvd-rw disc. However your cd burner must be dvd-rw not cd-rw. To verify your device open my computer (on most pc's) you will see drive c (your hard drive) and drive d which is your cd rom it should say dvd-rw.
You may also need dvd burning software for more information about this click here http://www.microsoft.com/windowsxp/using/moviemaker/expert/jones_02november25.mspx
Oct 18, 2009 | Dell Dimension E310 PC Desktop
Can't burn any more DVD's after burning first one
please uninstall your cd burner software, then install nero software. Nero software is used to make slide show, burn cd and etc. so I thing better to use nero. for more information contact my id smansari32@gmail.com. if your burner software did n't uninstall follow the step.
1. start your system
2. then restart your system
3. press f8 button continuously before load windows
4. select the safe mode using up arrow before files loaded.
5. select administator
6. give yes to all
7.goto control panel
8. open add or remover programs
9.then uninstall your software
that's it.
Jun 09, 2009 | CyberLink PowerProducer 2 for PC
After CD burning process nearly done write error ruins CD-R disc
I think u can identify this problem by checking step by step. At first change ur cd brande. If probelm still
then setup windows.. then try to write.
May 09, 2009 | Toshiba Satellite A105 Notebook
Cd burning problems
hello sir..i have a solution to your CD burning problem...sometimes if you are not regularly using your CD-RW drive then there are chances of CD-RW lense prob,so please do clean the lense using lense cleaner CD available in the market,even then if you not able to burb the CD then please do reinstall the software which you are using for CD burning...i suggest you NERO software for CD burning which is a user friendly software...
Oct 30, 2008 | QPS Que! Fire CD-RW Burner
DVD/CD RAM Devices
try some 3rd party software, nero, magiciso, poweriso,,,to burn discs,,,
Or
try using XP service pack 3..
good luck.
Feb 23, 2008 | Dell (0Y435) Internal 24x CD-ROM Drive
Computers & Internet Logo
168 people viewed this question
David Payne
David Payne
