I recently inserted a finalized DVD-R disc into my Panasonic DMR-E80HP DVD recorder, but it got stuck on "read" and wouldn't eject. I tried shutting the power off and pressing the eject button, and while that usually works, this time it got stuck in "recover" mode. Is there a way I can eject this disc without taking the machine to a repair shop?
Comments:
May 23, 2009
- Are you sure that the Panasonic DMR-E80H has this feature? I have two models and neither of them have the little hole you describe.
I have a panasonic DMR E-60 and had the same problem. What I did was remove 2 side screws and 3 rear screws and lifted top cover off. Then if you are facing the front of the unit to the right of cd unit there is a little nipple that locks the mechanism. Push that in, which would be to the left if your facing the front of the unit. Then press the eject button. Mind you it must be plugged in to power. Be careful not to touch any of the green boards or metal. Hope I was clear. I sent it to panasonic but they wanted 40. just to look at it and up to 140.00 to fix it.
look on the face of the machine, near the dvd slot. what you are looking for is a tiny hole, the size of a pencil lead. some players, not all, have this manual release. If you are fortunate enough to have one of these little holes straighten out a small paper clip and use it as a wire to insert in the hole and release your dvd.
Comments:
May 23, 2009
- Thanks for getting back. As indicated, some but not all have this manual release feature.
Here is what I found on this topic on page 56 of your owner manual, it may help.
The unit is on but cannot be
operated.
≥Some operations may be prohibited by the disc.
≥Recording drive or playback drive have not been selected properly.
≥The unit is hot (“U14” appears on the display). Wait for “U14” to disappear.
≥One of the unit’s safety devices may have activated.
Reset the unit as follows:
1.Press [í, DVD POWER] to switch the unit to standby.
If the unit doesn’t switch to standby, press and hold [í, DVD POWER] for about 10
seconds. The unit is forcibly switched to standby.
Alternatively, disconnect the AC power supply cord, wait one minute, then reconnect it.
2.Press [í, DVD POWER] to turn the unit on.
14, 18
55
Cannot eject disc. ≥The unit may have a problem. With the power off, press and hold [∫] and [X, CH] at the same
time on the main unit for about 5 seconds. Remove the disc and consult the dealer.
May 23, 2009
- just in case you do not have an operators manual, here is a copy
I needed to replace me hard drive with a 160gb. After repluging, front panel says unformated disc....
(More)
I needed to replace me hard drive with a 160gb. After repluging, front panel says unformated disc. Help.
My DMR-E80H says every blank DVD I put into it is now "...a non-recordable disc." I've...
(More)
My DMR-E80H says every blank DVD I put into it is now "...a non-recordable disc." I've been using it for years and it just started this. I've tried two different brands that have both worked fine in the past. Has the record laser died or something?Can it be fixed or is it time to replace?
I have audio recorded on HDD and can playback DVD's as well with sound, too. But when I record new...
(More)
I have audio recorded on HDD and can playback DVD's as well with sound, too. But when I record new TV programs, I get video fine but no audio. Have tried pretty much everything settings-wise. Besides that, it has worked fine, but I am wondering the transition to digital broadcasting has something to do with it. When set to Video-1 (on my HDTV), the unit has picture but no sound, and that's what I get when I try to record. Cables all fine, and again, already recorded TV prgrms from past playback fine.
