Question about Whirlpool LSR7333 Top Load Washer
Drum not moving
Drum doesn't move. pump works. motor works. rubber shreds under machine.
    President:
  • 1,136 Answers
Hi, The rubber is from the coupler that connects the motor to the transmission. I can direct you through this if you would like.
The following are steps on how to change a Whirlpool Motor Coupling:
First thing you must do is to disconnect the power then remove the cabinet.
You should always remove the cabinet every time you start such procedure. Two Screws behind the console that need to be removed. Lift the console and let it rest on the hinges. Under the console unplug the Lid switch. Two clips which are found between the console itself and the top panel on each end (bronze in color). Release the clips, and pull the cabinet toward you to release it from the frame. It will come off completely.
- Then you take off the water pump with the two clips holding it onto the frame of the motor
- Then you get the pump out of your way.
- Take the two clips off of the motor and set it aside and there you will see the coupling replace and put back together. You will need to tap the new coupler on the shaft of the motor and on the transmission. I use a small hammer and a 9/16" socket. Once the coupler is on, line up the koles with the posts on the coupler and put it together. Now you can put the pump back on the motor and put the cabinet back on. Be sure and set the front lip of the cabinet under the front frame and lay the cainet back on the frame. Also, make sure the sides lock down on the tabs near the back edge of the frame.
I hope this helps you. Please let me knwo if I can assist you further. You can find the coupler on my web site part# 285753A @ www.whirlpoolpartssurplus.com
Vic
Posted on May 23, 2009
  • 10,865 Answers
The belt that moves the drum is broken resulting in the rubber shreds you see. If you feel that you can replace the belt, I can talk you through it. Other wise, it is best to have a repairman do it.
Washer does not spin. Makes noise but drum doesn’t move
replace the rubber drive belt, unplug the machine remove the back panel to reach it as they do get worn and will wash but as the load sits at the bottom of the drum in spin mode the drum becomes heavier when the washing is sitting in the bottom its harder to start the rotation eric
Jan 18, 2018 | Washing Machines
Washer making a humming sound want do anything else
what's the brand name and model number?could be the motor you hear humming,something could be stuck in the drain pump depending on the model you have or there could be a piece of clothing stuck between the tubs,a bad start capacitor but if the motor is humming either something is jammed and won't let it move or the motor could be bad but you have to send more info.
Dec 22, 2017 | Washing Machines
Clothes are being shredded in washer
it sounds like you have a bent piece of metal round the drum you will have to make sure the drum is empty with your hand very slowly move it round the whole drum if you find it with a small hammer don't hit it heard OK just tap it till its not going to shred your cloths OK if you don't find any thing you will need to look at the paddle in the drum to make sure there not Brock or moving OK hope i can help
Oct 22, 2012 | Maytag Washing Machines
I am replacing the coupler on my machine due to it not agitating and noticed oil on the motor under the drum. also found a small piece of rubber that doesn't look like it came from coupler. maybe from a...
the tranny is leaking and the coupling is broke,to many over loaded loads.just a matter of time now and the machine is just gonna stop moving if the transmission oil is leaking out,just use it as long as you can or replace the tranny with the coupling,it's easy to change out the tranny,also the rubber could be from the coupling,i've seen them fall apart and rubber pieces under the motor.send the model number and i can look up the parts for you
Oct 22, 2010 | Washing Machines
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number https://youtu.be/WGolkFlgl3Y
Jun 22, 2017 | Maytag Washing Machines
My ariens 824 wont go forward or reverse. snow thrower still works. wheels start to move a bit then stop
I would check your traction drive disc for wear or shredding.With low or little fuel in tank you can safely grab handle bars and lift machine up on it's auger housing.Then remove shield from under machine and inspect metal disc with rubber around it.If rubber looks worn you can get a replacement traction drive disc easily from most small engine repair shop's or go online and look for your nearest Ariens dealer.
Nov 18, 2009 | Ariens Garden
Drum will not turn during a cycle
Take a look at your filter, it is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out your pump too.
Mar 21, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Whirlpool LSR7333 Top Load Washer Logo
107 people viewed this question
Dan Webster
Dan Webster
Sal De
