Question about Proscan PS32125 32" TV
Very poor picture
I had not used the TV for about a year. It was unplugged. When I turned it on it has a picture but it is quite faint and there are thin white horizontal lines about an inch apart on the screen from top to bottom
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
  • your problem is called picture with retrace lines.
  •  your problem is in video output circuit
  • as you are saying that it was off for a year that means there is possibility of loose contact in that section.
  • plz check the following
  • supply to video output absent or loose print.
  • loose connector in crt base.
  • crt base loose
  • voltage on screen control or g2 absent or wire loose.
  • screen control located on flyback transformer mistuned.
  • hope this will help
  • good luck.
Posted on Oct 19, 2007
Lg tv power light comes on but screen stays blank
If you can't see a faint picture with the flashlight then the T-con board is gone. If you can see a faint picture, then the led driver or ballasts for the back lights quit. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 05, 2016 | LG Televison & Video
Turning off
Hi dcough2,
haev you tried to unplug it for some minutes, and then connecting it back again?
Anothwr thing to revise is if the socket is used for more than devices than the TV, it could also be weak power, so your TV image fait, or go dark, or it just shuts off because it have not enough power to use.
Jan 01, 2008 | Sharp Aquos LC-32D40U Television
Six year old 53UDX10B - Faint Horizontal Lines in Picture
This is a pretty common fault here Mike. I cannot remember the capacitor number, but it is right off of the flyback transformer and supplies the screen voltage to the picture tube driver transistors. You will need to get a scematic and trace out and check the flyback secondary capacitors for leakage, I am sure you will have more then on or two capacitors that need to be replaced. One more thing with this TV set. Look right under where the picture tubes are on the printed circuit boards, for an indication of fluid leakage or an oily substance. If you see any evidence of this, turn off the TV set and unplug it and call out a tech to try and clean off these boards before any further damage happens. Good Luck
Jun 24, 2007 | Hitachi 53UDX10B 53" Rear Projection...
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
SONY BRAVIA
If you are turning off your TV by basically unplugging it (turning off the AC power supply) then you will not hear the click of the solenoid which is activated normally by the Power button. The glow may well be the after effects of the screen being on for some period of time. Quite literally the "afterglow". This should be very faint and fade after some time.
Feb 24, 2009 | Sony BRAVIA KDL52XBR2 Television
Sony KF50WE610 Won't power on Red light flashes
I had this same issue with a 46" Sony. I replaced the bulb, and it is as good as new. I hope this helps.
Jan 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Faint black lines running vertically
did you try unplugging everything and resetting your cable box. then plugging it back in,
i got some faint boxes yesterday and that did the trick
Jan 02, 2009 | Toshiba 42HL196 42 in. LCD HDTV
TV won't turn on
When I try to turn the tv on, the green light flashes and eventually goes back to red. A very faint picture came across the tv a few times but didn't stay. The tv is only 3.5 years old.
Jul 10, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sanyo DS24425 TV Has No Picture and Very Faint Audio
DONT BUY SANYO ELECTRONICS THEY ARE JUNK
Jan 09, 2008 | Sanyo DS24425 24" TV
TV quits after a few minutes-get a blue screen, no picture and no audio
My best recommendation is to pull the back off it and blow the dust out. Dust is electrostatically attraced to the components inside and acts like a blanket. This causes overheating. Remember to leave your tv unplugged for at least an hour before taking the back off as the CRT (picture tube) will store a charge which can kill you.
Bill
Dec 30, 2007 | RCA T19408 19 in. TV/VCR Combo
Televison & Video Logo
71 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
