Question about Behringer EUROPOWER EP2500 Amplifier
3 8 ohm speakers 1 stereo amp 2channel a 1 channel b will this do dammage
3 8 ohm speakers with one 2 channel amp 2 8ohm channel a 1 8 ohm channel b will this hurt the amp
  • montgomeryen May 23, 2009
    Fast and useful information thank you!
    President:
  • 788 Answers
If you only have 3 (8 Ohm) Speakers and want to hook them all up, you will need to balance the impedance of the sides or you will be too loud on one side and not loud enough on the other. This will cause your amp to work harder on one side. (Not Good)
I did not see the speaker A and B in the instruction manual.
Because of that, I will state the following.
I would not recommend that you hook up anything that is unbalanced. I would use just a pair in two channel mode (This would give you an 8 Ohm load on each output). The manufacture recommends a 4 Ohm load for the best output of this amp. But the most important thing to remember is that your speakers must be able to handle this much power or the speakers will be permanently damaged.
This amp has Protection to cover: Full short circuits, Open Circuits, Thermal and HF protection, and stable into reactive or mismatched loads.
You could hook up all three speakers and the amp will work, but, I would not recommend that type of hook-up.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have managed to answer your questions and have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot give this post a “FIXYA” (Two Thumbs Up) rating then please comment to this post and I will try to help you further.
I try to provide the best FixYa experience.
Posted on May 23, 2009
I have two JBL MRX 515 speakers at 8 ohnms and two behringer bins at 300 watts 4 ohms running off a behringer EP4000 amp, would this be ok ? and not casue any damage to the speakers
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Behringer-EP4000-Amps-manual/id/23591dj795/t/2/
http://www.raltron.com/cust/tools/parallel_resistance.asp
It's ohm's law, dude. 1/a + 1/b = 1/total. One each 8- and 4-ohm speaker in parallel per channel would be 2.7 ohms (nominal). So it will work in theory.
How you manage the potential difference in volume between dissimilar speakers on the same amp channel is a mystery.
Distortion will kill any speaker, not power. Stay within the amp's usable range.
Jun 23, 2011 | JBL MRX515 15" 2-Way Loudspeaker Main /...
I have a 1200watt amp that's only providing 300watt output with 8ohm Behringer B212 speakers. Is there a resolution and what would it be?
I'd need to know more about the amp, but don't forget, amps are rated as their max power...
So lets take a 300W/channel stereo amp at 8 ohms.
Ok, it's stereo, so there's 600W
But the amp is capable of 4 ohm loads...well, now you can deliver 600W/channel, for a total of 1200W
In this scenario, your amp is doing exactly what it was designed to do with those speakers.
If you wanted to get the full 1200W out of the amp, you'd have to hook up 2 more speakers in parallel to the ones already there. This drops the impedance to 4 ohms per channel = 600W / channel.
Yes, the power is split among the apeakers...300W per speaker into 4 speakers = 1200W
so any way you look at it, there's your 1200W
Feb 27, 2011 | Behringer B212 600watt, 2-Way PA Speaker
How can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
Apr 08, 2010 | MTX (SLH-T7512X2-A) Car Speaker
How many watts is this amp
Specifications Power Output: 100 Watts RMS x 2 channels at 4 Ohms ≤ 1% THD+N Signal-to-Noise Ratio: 80 dBA (reference: 1 W output) Additional Power Output: 200 Watts RMS x 2 channels at 2 Ohms ≤ 1% THD+N
400 Watts RMS x 1 channel bridged at 4 Ohms ≤ 1% THD+N THD+N (Distortion): <0.25% (reference: 1 W output) Frequency Response: 20 Hz to 20 kHz (-3dB) Maximum Input Signal: 5V Maximum Sensitivity: 100mV Dimensions: 14.37 x 9.72 x 2.5 (365mm x 247mm x 63.5mm)
Jan 03, 2010 | MTX 4002 Car Audio Amplifier
What do you mean by the subs should have more watts than the amp.and subs mean woofer ? actually i dont know any thing abt this. what is 8 ohm stereo, 8 ohm bridged,4 ohm stereo. etc etc...?
If your planning on using a stereo system in your car or home you need to follow some rules otherwise your just wasting money. The watts of a speaker means how much power it can handle. The higher the number the more power it can handle, and usually the louder it can get without distorting. If your amp has more power or close to the wattage rating of the speaker you will blow the speaker, it can even get so hot it ignites. The amount of ohms is the electrical resistance the speaker provides. House speakers usually have 8 ohms where car speakers tend to use 4. 8 ohm stereo means your left and your right are separate channels and each speaker has 8 ohms. 8 ohms bridged means you bridge the left and right channel to increase the power output of the amp and you have to use either 1 8 ohm speaker, or 2 4ohm speakers in parallel to prevent damage to the system. Same goes for 4 ohms. If I remember correctly you want your sub(woofer) to have a wattage rating 20% higher than the amp. Remember if the speaker overheats its no good, but most amps if they overheat they just shut off until they cool off, but only if they state they have a thermal overload protection.
Jul 12, 2009 | Solid Audio Formula Series F2000 2-Channel...
Ok . i have a pair of crossfire subwoofers, @
Your amplifier is 4 channel... and only 2 ohm stereo capable.
You will get the most power putting 1 subwoofer wired in parallel on each BRIDGED channel.
This will give you a 2 ohm stereo load.
Both + on 1 subwoofer to + terminal on amplifier bridged channel 1
Both - on 1 subwoofer to - terminal on amplifier bridged channel 1
Both + on 1 subwoofer to + terminal on amplifier bridged channel 2
Both - on 1 subwoofer to - terminal on amplifier bridged channel 2
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | DHD NTX-3102 Car Audio Amplifier
I need speakers for my Onkyo A-911M integrated amp
A+B speakers = 4 channels 2 right 2 left
100 watts/4 = 25 watts per channel
RMS watts / channel = 25 x .707 = 18 watts/channel which is your average consumer stereo system
I would use 8 or 16 ohm speakers (not 4 ohm) -- almost any set of stereo speakers will "work" -- these will be 8 ohm and about 5 watt minimum / 40 watt max thereabouts
May 07, 2009 | Onkyo Audio Players & Recorders
Legend Amp hook up manual.
Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
Run the REM to your stereo power ant. Wire. if available.
Run the GND to Metal Chassis Ground keep it as short as possible.
Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
Hope this helps
Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Behringer EUROPOWER EP2500 Amplifier Logo
190 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
