Cant find the air filter
My panasonic PT-52LCX35 has a blue screen and says to clean the air filter and it is shutting down in one minute. The red light indicator is blinking 5 times every 5 seconds. Where is the filter located? The owners manual does not show it. Thanks!
Our TV did the same thing. After calling numerous repair shops, and hearing there was no such thing as an air filter, or they had never heard of one, I decided to try to fix it using a suggestion I read on-line.After disconnecting from all power, take off the back panel, and using some compressed air, blow out all of the dust that has accumulated. I had to use a box fan just to blow the dust out of the house! Afterwards replace the back cover and it should be good again. Hope this helps!
Posted on Jul 11, 2009
  • 92 Answers
Its probly either whare you replace the bulb on the side or back of tv or look for a door where you see or hear the fan
Posted on May 23, 2009
Where is the air filter located on panasonic tv PT-52LCX35
Download the manual. It should tell you there. You may need to locate the Repair and maintenance manual, not the user manual (and surely not the quick guide)
Oct 24, 2015 | Panasonic PT-52LCX35
Clean filter message reset
the filter will need to be cleaned and if the set still shuts down then I would suspect the fan may need to be cleaned and possibly replaced.
Aug 07, 2012 | Panasonic PT-43LC14 43" Rear Projection...
Where is the air filter on a Panasonic PT-52LCX65 Projection TV
THE AIR FILTERS ARE INSIDE THE ENGINE YOU MUST TAKE APART MANY PIECES LET A REPAIR CENTER DO THIS!!
Apr 25, 2010 | Panasonic PT-52LCX65 44" HDTV
Panasonic pt-61LCX65 osd air filter cleaning came on screen and the unit shut down in 1 minute. I would like to know exactly where the air filter is where I can clean it myself.
This is stright from Panasonic.
The consumer is not able to change the air filter. It will have to be done by an
authorized Panasonic service center."
Jan 22, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
How do I clean air filter on the Panasonic PT-50LCX64?
I feel bad for you having such problems with the vendor and the technician too.
The location of that filter could be a small window in the back cover itself. could be a plastic window to the left side of the unit and is only a piece of plastic poliuretane kind of black sponge about 5 by 3 inches size .
What im interested telling you about the shut down condition and is maybe even most important than where is the air filter (who is one of the more than ten posibilities why the tv goes to shut down.
Note:
if the air filter is totally obstructed i would give one of ten probabities of suspicious why the tv shuts down:
first because the tv's air duct is not really isolated. The fan can eat air by any side of the air filter base as i said if the filter is totally obstructing which is really extreme. besides maybe the other 2 fans could help to cool down the unit in that case scenario. In my experience Most time the air filter holds tons of dust but is not totally obstructing the air passing, and really some other problems are in the set.
This is the really critical to know: if any of those fans stopped or maybe any sensor is overheated or the lamp is coming to dead or who knows.. a diagnosis is needed for this symptom really common in DLP technology.
Apr 18, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM
CORRECTION TOOL; (LSUQ0100).
Good Luck, big IRISH.
Jul 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Jun 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
PT-52LCX35 Panasonic
I think i have found the fix
I kind of feel dumb for all the mess i have gone though to get here and if im right it is soo simple
Dont buy a panasonic haha jk
Directily under the panasonic logo is ur air filter
Pull off you speaker cover at the bottom of ur tv
Then directily under that log is a pannel with two screws
Take that off
now take can air and blow out the foam u see on your optical lense
top and bottom
be careful the optical lense cost $800 so dont turn ur caned air upside down
this is what i finaly did and so far so good
it has taken me over a month of taking my tv apart every night to see what was right infront of my face i hope this helps everone
Apr 01, 2008 | Televison & Video
Televison & Video Logo
348 people viewed this question
Top Televison & Video Experts
