Question about Western Digital (WD3200JS) 320 GB Hard Drive
320 GIG Hard Drive now thinks it is an 80 GIG hard drive
I have a Western Digital Hard drive. The model number is WD3200AAJB. About a month ago, my computer shut down unexpectedly during the boot process b/c of a black out. When i turned it back on, My hard drive wouldn't boot. When i tried reinstalling a new operating system, my original NTSF partition was listed as an unknown partition. The unknown partition size is approximately 80 gigabytes (actually it's around 76 gigs, but that's how much you really get from an 80 gig hard drive anyways). I deleted the partition and reinstalled my operating system with hopes that it would correct it's size problem. I've ran many different types of hard drive recovery software but none of them found a problem with my hard drive. Is there any way to restore my hard drive to the original size of 320 gigabytes? Since this problem has occured, I have been using a different hard drive in my computer to avoid any further damage. I would like to note that when i had an operating sytem on the faulty hard drive, it did function properly. Thank you for taking time out of your schedule to read this and i hope u know how to fix my problem.
  • Francis Duquette May 11, 2010
    If your hard drive had 320 gb, there is empty space.
    You could create new partitions on your hard drive to use the remaining empty space.
    You could do that by using the windows disk management tool that could be found by typing mmc in the command prompt, or with any partition manager tool like Easeus partition master.
  • 5,568 Answers
Enter your BIOS setup and check what the BIOS sees for hard-drive. It may not be assessing the drive size correctly so you may have to force it by manually entering the data it needs to see the drive.
Posted on May 23, 2009
I HAVE A WESTERN DIGITAL PASSPORT WD3200ML8P 320 GB. THAT IS NOT RESPONDING AND CAN RETREVE FILES
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
Sep 18, 2010 | Western Digital Passport WDXML800UE...
My western digital 320 gig external hard drive stopped working all of a sudden. it has not been physically damaged. when plugged in the lights just blinks.
you told that it has not been pysically damaged than why light just blinks ok first you see the cable is in good condition. next plugin you hard disk to your computer and listen if any kind of sound coming through your hard disk (sound is like tee tic) if the sound out comes like what i said some way it stuck or damaged let me know if it works
Aug 12, 2010 | Western Digital (WD3200JS) 320 GB Hard...
Western digital 100gb external hard
The model number needs to be verified. Can you please validate it. You can go to this site and validate its drive type http://www.support.wd.com/ enter the model number and look at Specifications. Most external drives that are older than 2 years are IDE though.
Jun 02, 2010 | Western Digital External USB 2.0 80 GB...
External hard drive not detected
Check your jumpers on the hard drive. DON'T leave it connected very long if the jumpers are not set for master / slave (furthest away/ closest to the IDE port on the computer or it can mess up the circuit boards on one or both drives! If you are using only one hard drive, set the jumper(s) for "cable select" (often abbreviated CS). If it still doesn't detect the drive, the drive may not have an "active" partition on it. You can solve that by booting to your OS installation CD -- assuming you have one!
Feb 02, 2010 | Western Digital Elements powered by WD 320...
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Trying to partition internal hard drive, taking along time!
Windows 98 thru Vista will partition format the hard drive during installation. Starting with XP, it can handle partitions over 1GB (1000MB).
If it is a new drive, let windows do a "quick format" during installation.
Jan 09, 2009 | Western Digital (WD3200JS) 320 GB Hard...
WD hd won't start up when turned on until you plug into usb
i cant put a solution for this but try the exact software for the disk which it came with this can help.Im also trying for the software
Oct 27, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Acer Aspire 5100-3583
What size drive is in it now? The user manual should tell you what size drive it can use. If you are not sure, the best thing to do is to go back with the same size. The brand does not matter. Is your hard drive IDE or SATA? What is the model of your laptop?
May 30, 2008 | Acer Aspire 5100 Notebook
320 wd external hard drive
It could be a faulty power adapter, or the control board inside the caddy is gone.
If you have the warranty booklet contact Western Digital , they should register your product and validate the guaranty.
If not go back to the shop the same if you pay with credit card for example, they can track your purchase.
If you do not get a replacement, well the most expensive part of your device is the Hard disk, and if you are lucky, and dont keep turning it on and off it should still be ok.
In this case buy a replacement caddy enclosure for your hard drive, they start from $10. Buy a good one for $25.
There are two kinds, pata and sata, I think yours is sata, check it out.
Apr 09, 2008 | Western Digital My Book Essential Edition...
WD Portable Hard Drive Not Coming On
open it it up take out the hard drive, purchase a USB hard drive enclosure and install the drive. hopefully the drive is still good and spin up
hope this helps
Jan 07, 2008 | Western Digital External USB 2.0 80 GB...
Western Digital (WD3200JS) 320 GB Hard Drive Logo
285 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
