Question about Dryers
Dryer will not shut off...
Maytag Model No: PYE2300AYW. I always use the Auto Dry settings, and recently the machine will not shut off. I noticed that some people said that theirs would shut off in the timed setting, but there was no heat. Please help. Thanks
    President:
  • 1,136 Answers
Hi, the dryer will not shut off because there is no heat
Get me a model# and I can look it up and assist you further
Thanks
Vic
Posted on May 23, 2009
Comercial maytag dryer will not shut off. tried replacing timer. heats up but will not shut offf
When a dryer heats but the timer does not advance especially on the auto. dry setting (not timed dry) the problem is usually always a airflow problem. What needs to be checked is for lint build up in the blower housing, a blocked or restricted. Also on Maytag dryers a problem sometimes is that the blower wheel drive hub where it connects to the motor is stripped so the blower wheel cant move air,typically if that is the case a rumbling will be heard when dryer starts and once again when the dryer stops a rumblimng noise will be heard.
GENE
Sep 23, 2011 | Maytag Dryers
Model #PYE2300AYW Dryer. Changed therm fuse. Died in 5 loads. Changed therm fuse/Hi limit. Died in one load. This is a fairly simple machine. Could op thermostat be taking all these out? Tnx
Your lint trap and/or ducting could be blocked. This will cause the machine to overheat and the thermal fuse shuts it off before it burns your house down.
Jan 30, 2010 | Maytag PYE2300AY Electric Dryer
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
Dryer stopped running with 30 minutes left and will not restart. Maytag Performa PYE2300AYW
Reset the circuit breaker for the dryer. Allow the motor to cool, It has over temperature protection that will shut down the motor.
The belt that turns the drum may have broken. I am not sure about this model, but most dryers have a limit switch on the base of the dryer next to the motor that shuts down the dryer when the belt brakes.
Dec 15, 2009 | Washing Machines
MY MAYTAG DRYER PYE2300AYW TAKES 2 CYCLES TO DRY THE CLOTHES
I would imagine your vent duct needs cleaning. We recently had the same problem and a duct cleaning kit from Lowes (about $40) took us from what felt like 'reasonable' airflow outside to "oh-my-gosh, what a difference!!", and left an astonishing pile of nasty, damp lint on the ground out there...
There's a good chance the same treatment would do the same for you. Hope it helps!
Nov 02, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Dryer model number PYE2300AYW will not start.
check your fuses in the dryer their is only one fuse that could shut down the whole dryer like that. Open back panel and get a volt meter and check for continuity on the fuses. HOW? first un plug it then open back then you will see the heating element their are 2 fuses on the heating element take off wires and check those.Then if those are ok look down thier is another fuses its long white with 2 wires comming out of it with a black center that should be your problem check it repair it run it . GOOD LUCK
Oct 12, 2009 | Maytag Dryers
Maytag Dryer quit working mid cycle
sounds like the timer,the only thermal fuse i know of is to protect from overheating which cools and resets itself
May 10, 2009 | Maytag PYE2300AY Electric Dryer
Dryer runs but does not dry my cloths.
Hello, If the dryer appears to be running ok but will not heat you probably have a bad heating element or switch. Usually the heating element.
I hope this helps
CYA Gator241
Feb 09, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
137 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
