Question about Beverage-Air MT17 Refrigerator Commercial
Beverage air mt 17
There is a fan switch inside the unit beside the light switch, when the compressor is not running you can turn the compressor fan on manually and let it run all the time. Why would you want to do this ,,,, get rid of excess condensate?
  • Beverage-Air Master
  • 1,252 Answers
Their web site says it is to maximize defogging.
http://www.beverage-air.com/images/glassDoorMerchandisers/manuals/809-005A.pdf
See if you can get to their web site. In the operations section, under initial start up, it talks about this. Can't find anything else on this.
Good Luck-Hope this helps.
Posted on May 24, 2009
Model mt 17-54 will not cool
Go to page 10 of this PDF=> MT Merchandisers (MT Series) If you do not have Adobe Reader Click=> HERE For Customer Service at Beverage-Air=> HERE Go through pg.10 and that should give all answers you need, Good Luck, Sea Breeze
Feb 23, 2012 | Beverage-Air MT45 Beverage Cooler...
I have a Beverage Air model MT 27. Coils have been cleaned and recharged with freon. Cooler will not cool below 50 degrees?
You'll need to check the back-pressure on the low-side of the system, you have a faulty compressor. If there is a condenser fan motor make sure it is running when the compressor is on.
Jan 28, 2011 | Beverage-Air MT27 Beverage Cooler...
Fan runs but the compressor does not run no
While moving the unit you may have jammed or budged the start capacitor which is keeping your unit from turning on. It is located in the back of the unit near the compressor it is oval shaped and silver in color with two wires running out of it. Get the number off of it, go online and search for beverage-air commercial freezer parts. You will need to have the model number to make sure that you get the right parts. Please rate
Jun 03, 2010 | Beverage-Air 11.8 cu. ft. / 334 liter...
Beverage Air cooler
I am assuming that you are talking about he compressor having an issue starting. The switch is probably a anti-sweat heater. Turning it off, helps prevent a voltage drop which will cause a compressor starting issue. I believe your circuit is just too close to maximum. Your issue is usually caused by an undersized wired circuit to handle the starting amps needed to get it running. If you could put it on a dedicated, 20 amp circuit, your issue may just go away. Check it out.
Dec 19, 2009 | Carrier Beverage-Air MT21-1 Commercial...
Will not cool. Fan runs, have cleaned coil.
The compressor may not be starting. Put your forehead against the nmachine when youturn it on or plug it in, You will feel the vibration of the pump. If it is not coming on, you may need a technician to what determine why it is not working.
Nov 17, 2009 | Beverage-Air MT27 Beverage Cooler...
I have a beverage air kegerator that seems to work fine, but the evaporator fan runs constantly. Is it supposed to run constantly, or is it supposed to cycle on and off with the compressor, etc.?
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
Aug 13, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
My mt 12 cooler doesnt blow cold just warm air
thermostat could not be set properly, compressor could not be running, unit could be low on freon. start checking some items and let me know.
Aug 03, 2009 | Carrier Beverage Air® Marketeer® MT12-1-B...
Fan runs all the time
The inside fan has to run all the time. It turns off it will not keep things cold. Not the fan outside in the air it shoulc cycle with the compressor.
Apr 01, 2009 | Beverage-Air MT17 Refrigerator Commercial
Beverage-Air MT17 Refrigerator Commercial Logo
436 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
