Question about JVC 5 Disc Progressive Scan DVD/CD Shelf System
Jvc compact componet system 5 disc dvd/cc player
Having problems with sound and picture
  • 34 Answers
Check if you have sound on the tuner if you do it`s the mpeg board under the cd mech thats faulty
craig:)
Posted on Jan 20, 2008
SOURCE:
My nx501 says invalid disc when I put a cd in I
Clarion NX501 Owner Manual Installation Manualit looks like this is mainly a dvd player,it does play disks with mp3's and wma files but,not compact disc files,read the manual,try a recorded cd with mp3s,
DVD Player System
Digital Versatile Disc System with CDDA capable
Usable discs:
DVD video disc, Compact disc
Frequency Response: 20 Hz to 20 kHz
Sound/Noise Ratio: 95 dbA (1W Ref)
Dynamic Range: 95 dB (1 kHz)
Distortion: 0.05%
Video system: NTSC/PAL
May 22, 2015 | Televison & Video
Loading Problem
No Disk issues on device players like DVDs are caused by the following problems
Dirty Play Heads (Optical lens)
Bad CDs or scratched CDs on the surface
Non Compatible CD formats such as DVDs that are designed for some geographical regions and play formats
Also low electrical current is a major problem too
Your issue could reside amongst any of these problems
Check your DVD compactible play formats if its compactible with the CD you want to play.
If its compactible, then I suggest you get a CD Cleaner to clean to clean to Lens.
Also check your current output and if low, get a voltage stabilizer
Check the surface of the CD if its scratched and get a replacement.
May 25, 2009 | Philips LX3600D System
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Jan 24, 2009 | Pioneer 1000 Watt 5.1 Surround Sound...
Setting up Unit
I called the JVC tech service rep. I went from the Cable box to the JVC unit with a Digital Optical Cable, from dvd/vcr player to jvc unit with a Composite Cable and Audio Cables. From cable box to tv with hdmi cable and from jvc unit to tv with componet cables and cable box to dvd/vcr with Audio/ Video and S-Video cables. This allows me to have the cable TV access and Surround sound in all mode. I have HD and Digital surround sound in three diiferent modes. Everything is working great.
Thanks for the opportunity for help just the same.
Sincerely, cthomas249
Sep 25, 2008 | JVC THD-50 System
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
No disc loaded warning message
First check the optical pick up is working or not or change with a new one.
this part is availble with JVC service provider in your area.
Jan 10, 2008 | JVC 5 Disc Progressive Scan DVD/CD Shelf...
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
That could meen that something is improperly connected. You should try to disconnect everything, and then reconnect it step by step.
Oct 11, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
JVC DVD player plays with distorted sound
Have you tryed a differant audio input on another set or on that same set. Are the audio cables good?? If all this is ok then the D/A converter inside the unit is defective and most likely it wont pay to repai sorry
May 25, 2006 | JVC XV-N40BK DVD Player
JVC 5 Disc Progressive Scan DVD/CD Shelf System Logo
59 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
