Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer stays cold but refrig does not
Hi, I have a GE side by side and lately I have been experience a problem with the refrig part the freezer stays cold but food is spoiling due to no cooling on the refrig side can you offer a solution.
  • daigs May 23, 2009
    Maytag 317 I have thi sexact problem...what is the solution?
    Thanks,
    Mark
    President:
  • 1,136 Answers
Hi, Look and see if there is frost built up in the freezer on the back wall.
If there is frost, it will not let air circulate properly and it means there is a problem in you self defrosting cycle.
Please let me know if this is what you find so that I can assist you further.
Thanks
Vic
Posted on May 23, 2009
  • 36 Answers
Hi there .... check if the fan that circulates the air from the freezer section to the refrigerator section is working or if it is ,is it spinning fast enough to throw the air across .....
My ge side by side profile tps24 is not cooling on the refrig side and the body of the refrig is hot. Any ideas?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Profile Artica PSI23SCN refrig. temp on the refrig side stays at 27 degrees. I turned up the freezer temp to 6 and the refrig went up to 31. I called arepair guy and he said he had a client with the...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 02, 2011 | GE PSI23SCN Side by Side Refrigerator
My refrigerator won't stay cold. The freezer is working but not the refrig side
I have the GE Monogram ZISB480 side by side. Once again I have your same problem of the freezer freezing (good), but the refrig does not go below 45-50. All the official repair guy did was do a quick 1 hour defrost. I did that also just two weeks ago and it was fine. Now it is not cold enough again. I just looked in the freezer using a mirror I was able to push a 2"x2" trap door open towards the fridge. It must be automated and malfunctioning. Why the heck the repair guy didn't work on that? This week I'll call for another repair job ($85 for him to just come to my door) and ask him to fix the trap door. -Bob
Nov 14, 2010 | GE Monogram Side by Side Refrigerator
Nine y/o GE side by side not getting cold enough
More likely a defrost heater. Look inside the freezer at the back wall. Any frost there? If so, turn off refrig., unload freezer, take back panel off inside freezer, and use a hair dryer to melt off the frost. Replace the defrost heater located at the bottom of the frosted coils. (New heater may appear different than original, but instructions are included) If you don't have the defrost heater on hand, just manually defrosting the coils and re-starting the refrig will get is cooling again for at least a week before problem will re-occur. (this give you enough time to get the replacement part)
Mar 21, 2010 | Refrigerators
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Ge profile Ps27sgra refrigerator and freezef are
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
G E side by side refrig . freezer cold but
you have a defrost system problem timer or heater or bimetal tst could have a electronic defrost timer
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side not cooling enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting,
Sep 07, 2007 | GE Profile PSS26NGS Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
476 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
