Question about Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator
We left the frig door ajar for 6 hrs, now the frig isn't working but the freezer is... where is the reset button? Thanks!!
Hello, We left the refrigerator door ajar for about 6 hrs on our Maytag MBF...KEW, now the frig isn't working but the bottom freezer is. Where is the reset button? Thanks!
  • 1 more comment
  • kloaz May 23, 2009
    Hi, fan motor is running, no frost build up.... Frig on top stopped working after door was ajar but the freezer is ok. We have it unplugged to see if that will help. Any other ideas? Thank you!
    Yes, compressor was running. We have it unplugged for a while.
    Had it unplugged for 3 hours, and now it's okay! Thx for your help and have a great holiday! krista & mark
    President:
  • 1,136 Answers
Hi, No reset button. Check and make sure the evaporator fan motor inside the freezer is running. While checking that, look and see if there is any frost build up on the rear panelin the freezer. Please let me know if any of these are the case so I can asist you further.
Thanks
Vic
Posted on May 23, 2009
  • 1 more comment
  • Victor
    Victor May 23, 2009
    The vents to the fresh food section might have plugged due to the heat entering for that length of time. Does the compressor run?
  • Victor
    Victor May 23, 2009
    ok... If ya need further help tomorrow, please let me know.Good Luck
    Vic
  • Victor
    Victor May 23, 2009
    I am glad it is ok.
    Please feel free to rate me response so that others and myself know how I am doing.
    Hope your weekend goes well!
    Vic
Upright freezer door was left ajar. The alarm keeps sounding, can you tell me where the reset button is located.
Hello Deena;
My name is Peter. I am a retired field service refrigeration technician.
There is no reset for the alarm. The alarm goes off when you are not maintaining temperature.
During the time the door was ajar, warm air got into the freezer either icing up and locking the cooling fan or forming a block of ice on the cooling coils (Restricting cooling air flow.)
The best thing you can do, unless you want a $300.00 plus service call to defrost everything, is to turn power off to the freezer. Open the freezer door. Have plenty of old towels to soak up the water in the bottom of the freezer as it defrost.
You did not provide a model number which is located on the inside wall of the freezer. Every 8-10 hours your freezer will completely shout down for 20-30 minutes where only the light works and the defrost heater turns on. The ice build up is too much for the defrost heater to handle.
In some freezers the defrost mode is in the control board, in others it is a separate component that you can repeat trip using a flat head screw drive.
Jan 26, 2016 | Freezers
Is there a reset button somewhere on my frig? My children left the freezer door open and now my frig isn't working.
Unplug for about 5 minutes and then replug power. This in most case's will reset the motherboards memory. After this possible solution I will not be allowed to send a clickable link to a Service Manual to assist you but I can send you a link to your models exact model providing your model was made for the America's LG, Whirlpool, GE, Etc: and most Refrigerators design's and that you are able to locate you model number. To contact me click here=> appl...@yahoo.com
Thank You, Sea Breeze
Refrigerators
Freezers
Jun 04, 2011 | LG Refrigerators
Freezer only getting 48' and frig side is only at 49 degrees
take the back panel off and see if the fan is running and if not see if it has power to it if it does replace the fan and see if ur problem is solved the coil underneath the fan should not be frozen even if the fan is gone out this could be a sign that the lil black element that runs through the coil is gone out now if all this is good and still same problem ur probably gonna have a freon issue and unless u know how to charge one i advise u call a tech and if its only 6 years old yes it worth trying to fix
Mar 01, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Temperature in refrigerator is now at 60 degrees even with the dial at setting of 9 other side freezer is fine
sounds like the defrost system is cutting up, it melts the ice in the freezer compartment to allow cold air from freezer to travel to fresh food side and back again, could be a damper control but very rare event.we use to have to melt ice manually in freezers now we have automatic defrosters do it for us. this is not the easiest repair but the defrost sysem is replacable and not the end of your frig.u can empty frig and turn it off for 24 hrs with doors open and let it defrost naturally,so as to make sure that it is a defrostsystem, after 24 hrs turn back on and see if it works correctly after 6 or 8 hrs, if so definite defrost problem.
Oct 08, 2009 | Refrigerators
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator Logo
848 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
