2003 Cadillac CTS Logo
Posted on May 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Key stuck in the ignition and wont let me out of gear
My key is stuck in the ignition and won't come out. It keeps saying starting disabled, remove key.
  • 3 more comments
  • candicedisne May 23, 2009
    Where are you???
    ok im here
    can sumone help me
  • Anonymous May 11, 2010
    i am so sorry i don't know why it our chat ended please forgive me contact me again if you want and thank you.
    still there
Anonymous
Level 3:
  • Master 10,319 Answers
  • Posted on May 23, 2009
Anonymous
Master
Level 3:
Answers
10319
Questions
5
Helped
3074667
Points
30576
The shank of any GM key hits a lever that locks the key in place when turned into any position other than the off position. If it stuch in off, the cylinder must be replaced
  • Anonymous May 23, 2009
    No problem
    Frank
  • Anonymous May 24, 2009
    the ignition cylinder will have to be replaced
2answers
No power to my gmc and now the key wont come out of the ignition?
It has to have power to remove the key. Jump it with another battery or charger. If you have power from the battery and no power to the inside. Check main fuses under the hood. If those are good, put power to the cigarette light, This will get the key out. Most likely have to replace the under hood fuse panel.
Key stuck in ignition
Hi Suzanne make sure youy gear lever is in park. Operate it a few times it may have a dodgy switch which will prevent key from being removed. Regards Jim...
Remove ignition key
2 u key 2?
key broken off
key wont turn
shifter stuck in park?
which, or?
Car won't start , said it was disabled for
THe key has a code in it that is read by the engine immobiliser. BY removing the key and reinserting you are giving the immobiliser a chance to read the code again. Give it a try. THe battery in your key may be getting low and needs replacing.
2answers
How can I get key out which is stuck in ignition of 2008 cobalt. It also won't start
This can happen if the battery is low / dead. To solve, connect a set of jumper cables between the battery in the Cobalt and a running car's battery. Shut off the running car. In the Cobalt, make sure all accessories (lights, radio, fan, etc.) are off. Step on the brake, then move the gear shifter fully into the PARK position. Next, either attempt to start the engine, or turn the key to the OFF position and remove it from the ignition.
I hope this helps & good luck!
2helpful
2answers
My 2004 chevy cavalier won't start it is stuck in
Your shifter cable sounds like it separated from the transmission or shifter or just broke. you are probably stuck in a moving gear so the neutral safety switch is disabling the ignition.
1999 chrysler concorde key wont come out of ignition
Some chrysler vehicle have a button in front of the ignition on the steering column that has to be pushed to remove the key other wise replced the ignition cylinder itself
1helpful
My key wont turn to off in order to remove my key from ignition while in parking
Ignition - Key Stuck In Ignition Switch/Won't Turn Bulletin No.: 06-02-35-005 Date: February 28, 2006 TECHNICAL Subject: Key Stuck in Ignition, Key Will Not Return to Off Position, Shifter Button Won't Release in Park Position (Adjust Shifter Detent Finger) Models: 2002-2005 Chevrolet Monte Carlo Condition Customers may comment on any of the following conditions: - The key is stuck in the ignition cylinder. - They cannot return the key to the off position to remove the key. - The shifter button won't release in the park position. Cause This condition may be caused by the detent finger shifting over time. This may result in mis-alignment and binding of the shift rod on the shift position guide.
WHERE YOUR SHIFTER IS YOU WILL HAVE TO TAKE IT APART ..MAYBE THE RUBBER BOOT IS IT THE WAY,OR THE SHIFT LOCK SELINOID WHENT BAD
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
