Question about Nakajima AE-740 Typewriter
Cursor stays in middle
The cursor of the typewriter stays in the middle & I can not get it to stay on the left side of the typewriter so I can start to type.  When I hit return it just always starts in the middle.  Help.. before I go crazy.
  • Jringer Oct 22, 2007
    Thank you that solved the problem.
    Thank you for your help.  That solved my problem.
  • 478 Answers
Try resetting the left margin to a place near the left side
Posted on Oct 19, 2007
Right side marker light stays on even when car is shut off 2000 Ford Taurus
Some cars lights(maybe not yours) stay on one side when the turn indicator is left on that side. Check your steering column turn lever is in the middle, not set to turn left or right.
Sep 22, 2015 | Ford Cars & Trucks
Wheelwriter platen latch removal
Very vague question. the left side you have to drive the pin out.
right side just a clip.
If the platen wont stay down you can carefully wire it down so it doesnt interfere with the carrier is moved to the left.
Or buy a used platen.
Sep 12, 2015 | Lexmark Wheelwriter 6 Series II Typewriter
Lights stay lit.
Do all the lights stay on? if so it's not completing the power on reset. Try this remove the batteries turn the T/W off for 30 sec., Restart.
THE MEMORY WILL BE CLEARED!!
DickyO
Apr 12, 2010 | Lexmark Wheelwriter 1500 Typewriter
Print head moves left and stays horrible noise
The problem is either something is interfering with the carrier movement OR the carrier homing sensor is broken/defective. First, turn off the power and manually move the carrier to the right side frame, check for foreign objects in the machine (pens, pushpins, paper clips etc.). Put some oil (10 weight) on a cloth and clean the chrome shaft that the carrier travels on.(by the rubber cogged belt). This is a common problem. If the sensor itself is the problem, take to a repair shop.(not common)
Nov 24, 2009 | IBM Wheelwriter 30 Typewriter
My typewriter keeps the cursor at the center when i want it to be aligned left, how do i fix it
It sounds like the L. margin is set in the middle. Return to that point, press mar. rel. key, backspace to desired location, press the L. margin key.
DickyO
Aug 19, 2009 | Lexmark Office Equipment & Supplies
RIBBON WONT STAY DOWN WHEN YOU TYPE
Carrriage assembly could be broken, otherwise screw is popped out of gear in the right. With carriage all the way left, take out screw in the middle of white gear, pull out gear and pin, push down carriage top, insert pin in carriage and re-install screw.
Jul 02, 2009 | Brother GX-6750 Typewriter
I have a typewriter accuspell T34
Perhaps the L. margin is se allthe way to the right. Press the margin rel. key and backspace to the L. then press L. margin key. DickyO
Mar 27, 2009 | Office Equipment & Supplies
Nakajima AE-740 Typewriter Logo
127 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Adorjani Laszlo
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
