Overloaded it and now it wont do anything. Is there someway to drain it or reset it?
I overloaded my dryer, now it wont do anything. Is there a drain button or reset?
  • 3 Answers
You may have broken the drive belt which is easily replaced. No need to buy a new dryer.
Posted on May 23, 2009
Why does my frigidaire leq332ds0 sound like it's overloaded when it's not?
Good Morning Nikki,
I understand your Frigidaire dryer, model# LEQ332DS0, is squealing like it's overloaded, even after replacing the belt. There could be a number of possibilities that could be causing your appliance to squeal. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer and determine what is causing your appliance to squeal. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Dryers
Overloaded ERF EC11 and now rear wheels wont turn broken Diff?
possible but if you overloaded the unit I would be checking for a broken axle . Jack up the vehicle and turn the tail shaft to see there are any violent noises indicating a pinion gear/ crown wheel gear failure. remove drain plug to check for metal pieces on magnet
Jan 26, 2014 | Cars & Trucks
My GE spacemaker washer is blinking and will not work
I have a he gtup270emww washer used very little. The washer was overloaded and quit working full of heavy wet clothes and water. The washer agitator does not operate. The water does not drain.
The light blinks. I have un plugged the washer to reset the motor and lifted and closed the lid 7 times. I drained the water by hand.
When I try to operate the washer, it adds water for 30 seconds, the water shots off and the green light blinks.
What is the fix?
Mar 24, 2013 | GE Spacemaker Washer and Dryer Electric...
Frigidaire electric dryer model gleq2152es1 lights wont turn on and wont do anything
Hi ana piedranayari05, this is AP! Thank you for your post
I understand you are having trouble with your Frigidaire electric dryer not turning on. Make sure the dryer is still plugged into the outlet, and plugged in correctly. Also check to see if the house fuse is blown or circuit breaker tripped? If so, Replace fuse or re-set circuit breaker. Check to make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. Have a licensed electrician check to make sure it is on a circuit by itself. Additionally, the thermal limiter could have tripped or possibly an internal problem with the dryer. A thermal limiter automatically turns off the motor in the unlikely event of an overheated situation. A service technician must replace the thermal limiter after correcting the fault. If you have check the plug, fuses, and circuit breaker and still no power I would recommend contacting a local technician to diagnose and service your electric dryer.
Jan 18, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Dryer noisy while running overloaded yesterday
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 09, 2010 | Whirlpool ET8CHEXSQ Dryer
Washer won't spin
Try a different spin cycle on another setting if it still doest work try removeing the clothes and changing it to a normal wash cycle. If no try unplugging it for a minute or 2 and then back in hopefully it resets and if still no movement on the unit at all you may have overloaded it causing the motor to wear prematuraly and burn up. This is very common with overloading.
Aug 06, 2009 | Whirlpool LTE5243D Top Load Stacked...
Washer wont work
i would check the lid switch first,then tip the washer back and look behind the motor and see if the motor coupler is broken,let me knoe what you find-mike
May 23, 2009 | Kenmore 22422 Top Load Washer
My frigidaire dryer had burning rubber smell now wont turn on
soulds like the fuse in the unit overloaded, fluff or oter items may have fallen onto the element, or the unit was overloaded, and the belt was slipping on the motor drive pulley. check for rubber drive belt debri. replace damaged items as required.
Jan 25, 2009 | Frigidaire GLER642A Electric Dryer
I have a Maytag LAT9400AAW. I started a (large) load and it filled and started screeching and smoking. I thought the dryer was on fire until I unplugged the dryer and got behind it. I stopped the washer. ...
You have overloaded you machine. The sound you hear is the belt burning of the machine, Please limit the size of the loads and hope you did not do further damage to you machine
Jan 19, 2009 | Washing Machines
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
