Question about Craftsman Garden
Left wheel does not turn, axle turns but wheel does not turn.
I have a Craftsman 5.0HP rear tine tiller and the left tire/wheel does not turn. I see axle turning, but tire/wheel does not turn. The cotter key (not sure what else to call it) outside of hub was gone, but I put a piece of steel thru openings, but still the tire/wheel does not turn.
  • jmyhan0053 May 25, 2009
    Thanks very much for the response....I'm not too handy making such repairs, but I'm going to give it a go!
    Thanks
  • 284 Answers
You need to remove that wheel and replace the key stock
the axle and wheel should have a factory slot cut in the drive axle and wheel itself
1/4 inch key stock is the most popular and it can be found at most hardware stores.
You also could have what some would call a half moon keyway in the center of the shaft which you cannot see untill you remove the wheel.
Posted on May 25, 2009
Tines on tiller
-Check the locking bolt that hold the tine shaft to the main shaft. Possibly it's broken. If so replace new bolt. you should be good to go again.
Good Luck
mai
May 24, 2014 | Craftsman 17 In. Dual Rear Tine Tiller
Tires and tines will not engage
model number would be VERY helpful here because craftsman made many different styles/models throughout the years
Nov 28, 2013 | Craftsman Garden
My craftsman rear tine tiller m# 917293202 will not move tines will move but wheels will not
hello, upon inspection of the parts brake down looks like you have broken the drive chain inside of the trans to drive the wheels,there is no mencion if the belt and pulley turns and the wheels don't,did you check the belt and pulley?hope this helps,oh bring it over abd i will repair it,
Feb 12, 2012 | Craftsman Garden
I have a Craftsman 17" rear tine tiller with
check to see if there is a snap ring on the shaft or a roll pin.
Feb 23, 2011 | Craftsman Garden
Have a 7.0 craftsman tiller the tines go into gear but the wheels will not engage
I have a similar unit and it will require getting into the gearbox which is not an inexpensive venture. Just to be sure though, make sure the shear pins in the axles are ok. Hopefully it is just a bent/broken shifter in the gearbox but a shop visit will still be expensive if you cant do it.
Jun 12, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
We are trying to remove the wheels and tines from the craftsman roto tiller in order to replace a broken drive chain. We are having a very difficult time getting the wheels and tines off. Any suggestions?
there should be a cotter pin or pin holding a large washer once you have removed these then you have to get the wheel to slide off the axle it has a keyway on it.i have taken a hammer and hit one side of the tire on the backside then turn the tire half way round and hit the tire from the backside and walk the wheel off the axle.if the axle is rusty shoot wd-40 around the axle and wheel .the wheel should slide back on as you line up the keyway when putting them back on.if your going after the chain the tines will have to come off too and the chain box split
May 28, 2010 | Craftsman 8.50 Torque Rating Dual...
I have a craftsman 19 in dual rotating tines, rear tine tiller. # 917-293493. In mid till, the tines quit turning. Won't shift into any gear. Wheels are locked. Any ideas?????
It is going to be a transmission issue. You can try with the engine off, turning the trans pully by hand in the opposite direction that the motor was turning it.
Some gears in the trans got crossed up and locked.
Aug 12, 2009 | Craftsman Rear Mount Tiller
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Wheel shaft seals on troy bilt pony 7 hp.
If the seal fits over the axle shaft it should be ok. be sure your axles are very clean as not to ruin the new seals when applying them. probably a good idea to replace them as a pair (right and left side) to save you time down the road.
Oct 20, 2008 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
254 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
