Question about Dryers
How do I check a thermal relay switch for a kenmore dryer? Should it be open normally? Mine is.
  • ssv01 May 23, 2009
    I hope it's the unit as it is open in a stand alone mode, ie. no wires connected to it.
    Thank You.
    Vern
    Thank You Vic.
    Vern
    President:
  • 1,136 Answers
Thermal fuse or stat? They should be closed normal.
Does this help?
Please let me know if I can assist you further.
Vic
Posted on May 23, 2009
  • Victor
    Victor May 23, 2009
    You are very welcome
I have Kenmore 90 plus series electric dryer that won't stay on after I let go of the start switch. I replaced the thermal fuse, it was blown. I also replaced the start switch, it only makes the dryer...
I think there is a Relay that is bad, the start switch is activating that relay, but that relay fails to stay on the way it should. Find that relay and check it and the wiring connections.
Sep 24, 2014 | Dryers
Why wont it start?
Check for 240V at the motor terminals and work backwards from there.
Aug 18, 2014 | Kenmore Dryers
Kenmore elite gas dryer won't heat.I tested thermal fuse, high limit thermostat, thermistor and gas valve. All within spec or have continuity.
Hello Chuck,
In addation to what you have checked here is a list of what else to check
Flame switch...black box on burner tube...check for continuty
Ignitor...check for 120 vac too it
Timer/control board heat relay..on models w/timer check for contunity in heat circuit on timer. ON models w/control check that heat relay on board is closing and has continuty
Motor switch..check that heat circuit is closed and has continuty when motor is running and motor switch has closed for heat circuit(the start winding switch on motor will be open when running)
WARNING..WHEN PLUGGED IN FLAME SWITCH WILL BE LIVE ALL THE TIME AND SHOCK YOU WHEN TOUCHING..BE SURE TO DISCONNECT POWER BEFORE CHECKING
Gene
Aug 09, 2011 | Kenmore Dryers
Kenmore 500 series gas dryer has no heat and no glow. Thermostat fuse has continuity. Replaced ignitor and coils. bypassed flame sensor and still have the same problem.
Having checked or replaced what you have thus far here a few things still to check
Cycling thermostat in blower housing,in addition to thermal fuse it must have continuty to be good
Timer check wiring diagram in control panel and check for continuty that are supposed to be closed when set to a normal heat cycle
Motor switch heat circuit check again with wiring diagram and see which wires on motor switch must be closed when running so dryer will heat.This a built curcuit asurring the dryer will never heat when motor is off
If your model has it check heat relay in control panel for continuty on heating circuit for relay(not the circuit that closes relay)
as far as power to the ignitor the hot side comes from timer to and through the thermal fuse and cycling t-stat, to ignitor.the neutral comes from neutral wire on cord to and through motor when motor is running and motor switch is closed
so on ignotor plug check hot wire to ground(not neutral) if has 120 vac to it timer/t. fuse/ cycling t-stat and flame switch are all good and its the motor switch is the problem.The motor switch can not replaced seperatly and must replace entire motor
Gene
My Kenmore 110.66962501 dryer doesn't start.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
Thermal Fuse Video Door Switch Video
Jul 20, 2011 | Kenmore Dryers
The dryer is doing nothing when I set the time and push the start button. I have omed out all the fueses and have made sure the door is shut. I have used my multi meter and I am getting the corect voltage....
Check your door switch. It should be a normally open switch. If it's good, you will need to check the thermal fuse and or thermal cut off. This is where you will find the problem. When you find the one bad, you will need to replace the cycling thermostat. It's a normally closed switch that closes on the rise. Once the temp gets to the degree on the cycling thermostat it opens, cutting power to element. When it goes out, it will not open. Then the dryer cycles off of the thermal cut off. This results in the dryer getting real hot and then the thermal cut off will be put out or the thermal fuse one. Your on the right track, keep looking and I feel sure you will find it. By the way, these parts I listed are located on the vent housing close to the blower housing. Good luck.
Oct 16, 2009 | Kenmore 700 6972 Dryer
Dryer doesnt start, 600 series kenmore
Q - My dryer is dead, what could do that ?
A - Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first, then it is sometimes a good idea to replace the operating thermostat at the same time. This is a picture of -some- modern thermal fuses.
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Apr 01, 2009 | Kenmore 63942 Dryer
Kenmore gas dryer will not run. m# 77930100
Verify power at the wall outlet.
Check the door switch for continuity.
If not the door switch replace the thermal cutout relay.
Feb 21, 2009 | Kenmore 63942 Dryer
Dryer won't run
take a look at your start and door switch
May 24, 2008 | Kenmore Elite HE4 Electric Dryer
Spins fine but no heat
I solved the problem. The problem was the heater relay. Once I troubleshot the system and realized the wiring was likely good, the only answer was the heater relay. Since the heater relay and motor relay are identical I swapped them to make sure and now the motor didn't work. Picked up a new relay for $30 and it was fixed...
Dec 08, 2007 | Kenmore 63942 Dryer
Dryers Logo
123 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
