Question about Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
Grinder wont turn and toilet not flushing
Toilet only a few months old and toilet get water but wont flush and I can hear the moter come on but it sounds like the grinder is stuck.
    Problem Solver:
  • 17 Answers
Disconnect the power and pull the pump out and examine the pump. Simple and easy!
Posted on Jul 07, 2009
Re. Duravit Happy D toilet (tank No. 0929100005)
Remove and clean the flush valve and the flush valve seat(it is the flap that opens up to allow water to flush the toilet). Once the edges of the valve and the seat are cleaned, possibly with "0000" grit bulldog steel wool, it should not leak anymore. To make sure it is not leaking, once tank has refilled completely, put some food die in the tank. If, after 10-15 minutes, the water in the toilet bowl is colored, you have a leak from the flush valve. Replacing the flush valve is very easy - just bring the old one with you to the hardware/plumbing store and ask for a replacement. Blessings and good luck!!
Sep 23, 2017 | Duravit Home
Kohler flush problems
If it has a power flush (i.e hole about 1" in size opposite side of flushing direction) that hole gets plugged by minerals from the hard water, when it does the flush will be much weaker. To clean it, use a bent coat hanger and ream out the deposits as far in as you can reach. Then turn off the water supply, flush the toilet, then quickly pour one pail full of water into the toilet to drop the water level to minimum. Get "Lime Away" at H/Depot, pour in 1 cup and let sit overnight to eat the remaining hard water deposits from the bowl and power flush. In morning turn on water flush a few times, should wok good as new. Repeat anytime hole starts to get plugged.
Aug 21, 2014 | Home
Toilet flushes but does not have the power to flush down waist
Aug 14, 2014 | Home
Toilet wont flush
Jul 27, 2014 | Home
Toilet not flushing completely
Prelude:
My toilet had the same problem a few times. I managed to clean it out because the pipe is somehow connected to the downstairs drainage pipe in my house. What fixed the toilet clog was going to the source of the problem and pouring extremely powerful hair clog remover chemicals in it (I did have to open all the windows and get the pets as far away as possible and wear a mask). After the specified amount of time waiting, I went to go flush and it worked.
**Answer**:
I would recommend doing the same thing but only if everyone in the house is gone for 1 hour. Also I would air it out by leaving windows open, not first floor doors or windows though. It can be deadly if inhaled for extended periods of time. The more powerful the cleaner, the better the results but the deadlier it can be if inhaled. Try this.
My second guess is that it may be the plug inside the toilet's tank. You should check to see if it is working properly. Try flushing with the lid off and watch the plug to see if it is working properly.
Mar 13, 2014 | Kohler Home
Toilet wont flush
Main 3 (or 4) inch drain under the toilet is clogged. Requires removing the toilet and running a "snake" down the pipe. Alternately, you can (carefully) try manually filling the toilet bowl all the way to the top----to apply pressure to the clog....it may push it through.
Mar 04, 2014 | Home
My Sanilflo system is fed by a toilet and a sink. When the sink fills it to operating the grinder runs for about 5 seconds and switches off. When the toilet is flushed (no solids) the grinder runs for...
The amount of time that the pump operates is determined by the amount of water that is drained into the unit. If the amount of water from the sink is less them the amount flushed then the pump will run accordingly.
Mar 06, 2011 | Saniflo SANIBEST Pump Macerator Grinder...
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Toilet pumps bursts of water
either your fill valve needs replaced or your flush valve needs replaced
May 13, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round Logo
633 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
