Question about Toshiba (K000002020) Motherboard
A.c.adapter and mother board
Im trying to find out what the a.c.adapter has to do with the mother board. my toshiba laptop will not charge unless u hold the charger in. Im told that it is the mother board.
  • Toshiba Master
  • 2,404 Answers
Its a problem with the dc jack in the laptop, thats where the charger plugs into.
The solder joints are loose to the jack and need to be resoldered. It will tighten the connection of the jack to the motherboard so that way you can plug in the ac adaptor and not have to hold it in.
An electronics shop can do this or if you have some soldering experience you can do it.
Ben
Posted on May 23, 2009
Toshiba satellite hangs when adaptor is pluged in
If the laptop works fine with the battery but fails when the adapter is plugged , the there are transient voltages from the adapters SMPS. You will need to remove and check for failure of capacitors, possible the main tank capacitor is leaking or under value.
open and confirm but do not connect to laptop unless this is checked as you can damage the mother board.
Apr 06, 2011 | Toshiba Satellite A200-1DA Notebook
I have a toshiba LT a205; the LED flashes 6x; what does that mean? the psu is rated at 19vdc, and puts out 18.5 vdc. The end of the power connector that goes to the mb only has 0.5 vdc on it, so I'm...
19volts is a nominal value. The AC Adapter will be fine from 18 volts up to 20volts because the power unit on the motherboard regulates the voltages very accurately.
You say you only have 0,5volts on the Mother Board power input. There's your fault. Between the Mother Board socket and the AC Adapter.
Replace the AC Adapter or Laptop Connection lead if you mean there is 0.5volts actually on the Mother Board but full oiutput from the Adapter.
Dec 15, 2010 | Toshiba Satellite A205-S4777 Notebook
Toshiba Satellite P30 (new) Battery (and old) not charging
Your charging circuitry, inside the PC may be faulty. OR maybe the Power Adapter, you need to try another adapter, if the problem does not go away, then you have an internal motherboard power supply problem it will have to be serviced. Or just maybe the second battery is faulty too, unlikely.
Mar 26, 2010 | Toshiba Satellite P30-S701TD Notebook
For laptop: Toshiba Satellite A105: My battery won't charge/computer won't turn on when plugged in. No lights show when plugged in. Don't know if it's a problem with the chord or the computer. Don't want...
Start by trying another power outlet.
The power adapter should have its own light. If it doesn't light up then the adaper is bad. Kensington.com sells very inexpensive universal power adapters. You might also find a good deal on eBay.
If the adapter lights up then it may be your battery. Notebook batteries are only good for 2-3 years. If you let them sit for a long time without a charge they may only last 1-2 years.
Vote for this solution if it helps.
Aug 18, 2009 | Toshiba Satellite A105 Notebook
Sometimes power adapter charges sometimes it dont
the connector in the computer is connected to the mother board and it tends to crack (design flaw) thus the connection becomes erratic solutions are 1)replace mother board 2) if you know someone really good at pc laptops and slodering u open laptop dismantle and sloder connections 3) replace laptop 4) unfortunately live with jiggling until it charges
Jul 07, 2009 | Computers & Internet
Toshiba p25... this unit will not power up. when the power plug is plugged in, the front power led will flash once and then nothing. the unit will not power up with or without the battery installed.
hello...if you have extra ATX power supply can you try to replace then try to boot the unit if not working u need to try and remove board inside the casing and try to test only,Mother Board,Memory,Video Card And Power Supply of curse..thanks...^_^
May 08, 2009 | Toshiba Satellite P25 Notebook
Ac adapter light is solid green, but when plugged into laptop...
the most likely reason is a systemboard problem (the ac plugin port cannot changed independently for notebooks)
Mar 23, 2009 | Toshiba Satellite A65-S126 Notebook
TOshiba Laptop Not Charging or booting
check the power connector (on the back of you laptop - through whitch you feed power to the mother board) for lose or if it's broken
Oct 03, 2007 | Toshiba Satellite A60 Notebook
No power
Can you just clarify how much you are certain the adapter is OK......did you you for argument sake try another adapter. The battery might be poked or that adapter not going. I know laptops may get sentimental (so to speak)but they dont just shut down for no reasons technically unless the battery is stuffed or there is NO power to the unit. Thats why the LEDS are not lighting up?
Sep 06, 2007 | Toshiba Satellite A105-S4014 Notebook PC
Open Questions:
Toshiba (K000002020) Motherboard Logo
120 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
