Question about Refrigerators
The refrigerator door swings open without resistance and hits the counter behind the door
On a GE TFX26PPDA CC the refrigerator door swings open without resistance and hits the counter behind the door
    President:
  • 1,136 Answers
Hi, Check the hinge cam and closer kit on the bottom hinge. See if there are any cracks or even part of the cam mising. They have a tendency to wear sown through the years. If this loks like the problem, please let me know and I can get you part #'s for you.
Vid
Posted on May 23, 2009
I have a kitchenaid refrigerator with single door on top and pull out freezer drawer on bottom. When I open the refrigerator door it will swing all the way open and hit the counter top . How do adjust it...
It sounds like your refrigerator is out of level in the direstion of your door hinge. Under the front side, in behind the louver at the bottom will be two adjusting screws. Either raise on the hinge side or lower on the non hinge side. Or both. this should get the door to the point you should be able to let it loose and the door should, from any position, shut by itself.
Hope this helps.
Dec 19, 2014 | KitchenAid Refrigerators
Home Depot lists a depth dimension for a GE refrigerator. Is the handle included in the depth dimension?
no. depth is measured from the back of the box to the front of the box but does not include the handles. The depth of the cabinet is used to determine if the doors will open sufficiently to clear countertops and half walls or appliances. Also helps determine if enough space will be available to open doors in small kitchens such as "c" shape, "L" shape or narrow galley kitchens. for small kitchens, the best frig is a side by side. The doors are smaller and less swing space is needed. A 25 cubic foot side by side uses less swing space then a 15 cubic foot single door. If you are worried about depth, you can also get a counter depth frig which will stick out past your countertops by about 2 inches rather then 8-10 inches with a standard frig. standard depth is about 28-36 inches from the back wall when plugged in. Handles get in the way most often in width measurements because they prevent the doors from swinging past 90 degrees if located next to a wall.
Dec 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side fridge door swings all the way open and hits my counter next to it. It progressively has gotten worse over time. Is there a "stop" that is bad or just a hinge issue?
there are door stops that snap off on the bottom of the door,the part number is WR02X10782 and they're like 8 bucks,two screws hold it in place
Nov 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How do i stop a refrigerator door from swinging open too far?
It sounds as if your fridge is leaning forward and the weight opens the door to quick and to far, try to get it level and then it will only open as far as you open it.
Regards
Chris
Jan 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I just purchased a GE profile counter depth french door refrigerator. It seems fine except that the doors (both top and the freezer door) do not swing shut. They have to be pushed to close properly. We...
The doors are out of alignment.
pretty tricky to get right - and professional help is suggested.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2009 | GE Refrigerators
GE Side by Side Frig Door Flies Open to Far
Look under the front of the fridge, should be some adjustments to raise and lower the wheels or feet for leveling. Level it with a level on the top, should help keep the doors from swinging.
Sep 13, 2009 | KitchenAid KSCS25FKSS Side by Side...
Fridge door hits counter
as long as its not over 20 lbs on the door you will be ok
Aug 12, 2009 | U-Line Origins 1175R Refrigerator
R/H door swings open too easily and hits counter behind door.
Hi LC,
Your fresh food lower door hinge cam assembly has failed and needs to be replaced. Not a big deal to replace, really... but you have to remove the FF door to get to it. <---which is VERY simple to do. But first thing first, right? You'll obviously need the replacement part on hand prior to the repair, so the part number is WR02X10779. You can see what it looks like here (you could also order it here if you don't have a local appliance parts retailer).
OK, now that you have the cam assy., Empty out all the goodies that you have stored in the FF door shelves. Then using a sturdy step stool, remove the upper hinge cover. Below the cover, you'll find three more screws, remove them (just so you know ahead of time... after you remove the last of the 3 screws, the door is no longer "attached" to the frame, so hold on to the door while removing the last one, OK?). Now all ya have to do is lean the door forward (from the top) and lift it off of the lower hinge/cam assembly.
Now that the door is off, all that's left to do is remove the old cam assy., install the new one and rebuild everything! Easy Breezy! You'll be in and out of this job within 20-30 minutes.
Oh yeah... one other thing. When you replace the door and are putting the top hinge back on, put all 3 screws in but don't tighten them yet. You'll need to "level" the door and THEN tighten them. Just lift the fridge door handle 'til the top of the door is level with the Freezer door, tighten the screws while holding the door in this position, deal? Cool.
Hope this helps!
SG
May 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side Fridge Door Adjustment
Most refrigerators do not have anything to prevent the door from opening all the way. To minimize this , adjust the front leveling legs up enough so the door won't stay open by itself. The refrigerator doesn't have to be level, it just should not rock. Most are adjusted this way to let the door shut itself. This should help. If this doesn't work. make a strap with small chain or seat belt type material. Attach from the bottom of the door. Make it just long enough to not let the door open past 90 degrees.
Jul 02, 2008 | GE Refrigerators
Counter depth refrigerator
Do you have room to pull the fridge out from the wall, maybe just a couple inches? Pulling it out from the wall should give you more door swing without hitting the counter.
Let me know if this works for you.
Thanks,
Bill
May 16, 2008 | Refrigerators
Refrigerators Logo
444 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
