My printer is feeding more than one page at a time my printer is cannon 3000
  • 684 Answers
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
If it still fails to feed the paper correctly, please reply with the following information:
What type and brand of paper were you using? Have you ever used this type or brand of paper before and if so what were the results?
Posted on May 23, 2009
Always paper jam error on my cannon 3530
Check for a paper fragment at either end inside the printer chamber or underneath the paper feed roller cover plates. Anything that holds a paper feed sensor arm open will give you paper feed errors, and they can be remarkably small.
May 14, 2015 | Cannon Office Equipment & Supplies
Cannon mx459 will not feed copies at ALL!!!!!. hAVE TO PLACE ALL COPIES ONE AT A TIME TO COPY. DO NOT HAVE TIME FOR THIS
Your ADF feed rollers are worn or dirty. Clean or Replace the rollers and it should pick up pages again.
Oct 13, 2014 | Canon Pixma Mx459 All-in-one Inkjet...
Paper Feed problems for Cannon MP600
Mechanism Problem replace the mechanism with new one.
Jan 01, 2013 | Canon PIXMA MP600 all-In-One InkJet...
Is there a free download for cannon LBP 3000 for a mac
Cannon LBP 3000 Driver
Please visit the above link from Canon Official Support & Downloads. Select the OS (Operating System i.e. Mac OS) and get the drivers for free.
Hope it helps! Good Luck!
CreativeTECH
Feb 26, 2011 | Canon LASER SHOT LBP-3000 Printer
Cannon MP460 will feed paper through printer but not print
Check your printer sharing in the system preferences... make sure it's on.. then when you get the print window, look for your printer under shared printers... try it that way... worked for me on my wifi network here.
Mar 23, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Cannon printer feed paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Canon PIXMA iP1600 Printer
CANNON IP5200
According to the service manual, that is an 'ASF (cam) sensor error' and solution being to replace the 'Sheet feed unit'.
Jan 18, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Off Line Cannon Printer
Try the following start->settings->printers right click on cannon bjc 3000 and check for a tick mark on "use printer offiline". if the tick mark is there then click on the "use printer offiline", then try a test page. hope this helps
Apr 07, 2007 | Canon BJC 3000 InkJet Printer
407 people viewed this question
jasbo
jasbo
