Question about GE Profile PSI23NCR Side by Side Refrigerator
Ge side by side dispenses ice but not water. water button clicks but does not humm
  • 1,543 Answers
Remove lower grill and disconnect the water line going through the freezer door hinge. Usually it is a push lock fitting, which requires you to push the ring on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X101073 water tube heater. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
Comment by MNTECH, posted on May 20, 2009 Sorry, didn't notice that I put an extra zero in the part number. It should be a WR49X10173
Posted on May 23, 2009
How long before line will thaw out?
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: ge side by side dispenses ice but not water. water button clicks but does not humm
Posted on May 24, 2009
I have a GE Profile Performance side by side refrigerator and I can no longer get ice through the door. I can get water but the ice and crushed ice just humms . It does not dispense. Any ideas?
The humming you hear is probably coming from the motor not being able to turn the auger. Check to see that the auger is intact. I have seen where they come apart and get jammed up. Here is the part to order in case you find it bad.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | GE Profile Performance 25.2 cu. ft....
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
My GE side by side fridge doesn't dispense water.
When you press the handle, do you hear/feel a click?
Is this just starting to happen after a power outage?
Is the ice machine making ice? Dispensing?
Do you have/know how to use a multimeter to check voltages at the water valve solenoid?
Thanks!
Feb 21, 2010 | GE (ESS25KSTSS) Side by Side Refrigerator
Ge side by side dispenses ice but not water. water button clicks but does not humm I would like to know how long it takes to thaw a frozen line to the water dispenser?
May 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE refrigerator GSS25JFMCWW not dispensing ice but dispense water
I have the same problem with the same unit. I removed the ice tray and held the open door cut-off switch closed. I then pressed the lever to dispense ice. I hear a humm like power is getting to the motor but the motor is not turning. I hear a click like the selonid is engaging. I'm having to assume at this point it's the motor and I am going to go ahead and order a motor. I've found a motor for the unit at partselect.com for $65.54. Hope this helps you.
Apr 21, 2009 | GE GSS25JFM Side by Side Refrigerator
Ge side by side is making ice but water dispenser stopped working
check all hose connections and if those are good push your butto for water and see if it humms or clicks.if it humms the water valve might have gone bad or their is not a connection in the hose some where.if you dont hear it click then it is broke behind face.check all components to water side for break or bad switch.
Mar 08, 2009 | GE Profile PSI23NCR Side by Side...
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model TFF24RWC Side By Side Ice/Water not Dispensing
I had that issue and a myriad of other issues with my GE side by side fridge. I replaced the control panel $100 and all three problems I had went away immediately.
1. Ice and water dispenser quit working
2. Howling noise 12 hours out of the day
3. Clicking noise
Jan 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSI23NCR Side by Side Refrigerator Logo
197 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
