Question about Microsoft Publisher 97 Full Version for PC
Unable to open a Publisher file a second time without rebooting PC
When I try to open a publisher file a second time, I get the message below and can not re-open that file until I reboot the computer. MS Publisher This file is being used by another currently running instance of Publisher. Try closing other instances of Publisher or saving your work in those instances; then try again.
  • nellie3402 May 24, 2009
    I still have XP and not Vista. I have uninstalled and re-installed MS Publisher 97 before writing for help. As far as I know, there are no other instances of Publisher, but will check task manager. It was working ok until about 3 or 4 weeks ago. Only thing I have done different is switch from dial up internet to Charter High Speed internet. Thank you for your reply...J. Irwin
    President:
  • 688 Answers
Have you upgraded from xp to vista since you installed the microsoft publisher?
it sounds like your publisher is not closing the prior instance running. you can bring up the task manager and watch what is happening when you open and close instances in publisher. in task manager click on processes and watch what comes and goes as you work with publisher.
then if it continues, i would reinstall you publisher all together. the consensus among the gurus is it will running but it 11 yrs old and may have issues that can;t be patched for vista.
Posted on May 23, 2009
  • Steve Brown
    Steve Brown May 24, 2009
    It appears something occurred between when it was working and now to cause the problem.
    here is a link to the miscrosoft installer clean up utility.
    http://support.microsoft.com/kb/290301
    Download it and run it...it helps remove files left over from microsoft installer.
    Warning: if your running Office 2007 don't use it to remove Office 2007 installer files.
    Also you can download HiJackThis and run it to see if a spyware, adware or trojan could be tying it up somehow.
When I open the product I get the message "Unable
Is the machine connected to the internet? It might need an internet connection in order to register the product fully.
Mar 15, 2011 | Greenstreet Software Publisher 4 Full...
I have microsoft publishr on my desk top computer but I dont have the disk.I bought microsoft Publisher 1993 as I was told it would open the files I have on the memory stick I also have the microsoft 98...
...why are you still using publisher 98? Never mind. Whoever told you that 93 would open a file created with 98 was lying; the programming likely isn't compatible. At this point, you'd need to look REALLY hard for someone with the expertise AND tools to get that data for you. I definately have the expertise, but publisher 93 is almost as old as I am, so i doubt i have any of the necessary software lying around. If you use a more modern version of publisher, like publisher 2003, you might get lucky. i don't remember if 2003 is backwards compatible, but it probably is. But if anyone tells you that any computer or program from that era is forwards compatible, they are LYING. So to answer your question, try buying office 2003, and open it with publisher 2003. It might work then.
Feb 11, 2011 | Microsoft Publisher 98 Full Version for PC
Hi, I've just installed Microsoft Office Publisher 2010 on my PC (Vista Basic). It works fine and everything. However the saved publisher files have icons like blank pages and won't open automatically...
Hello:
You can manually locate Microsoft Publisher when going to the "open with" dialog. Follow the steps below:
  1. Right click on a Publisher file.
  2. Choose "Open With..."
  3. Choose "Choose Default Program..."
  4. A dialog box will open. There is a list of programs at the top.
  5. Near the bottom of the dialog box, there should be a link that says "Browse..." Click it.
  6. You need to locate the Microsoft Publisher Program. For Office 2010, it should be at:
x86: C:\Program Files\Microsoft Office\Office 14\MSPUB.exe
x64: C:\Program FIles (x86)\Microsoft Office\Office 14\MSPUB.exe
7. Click once on the file and choose "Open" 8. Check the box called "Always use the selected program to open this kind of file" 9. Confirm your selections and click "OK" at the bottom of the dialog box.
Jan 27, 2011 | Microsoft Office Professional 2010
Webworks 7 wizard unable to scan document: While trying to generate a *.CHM file using the Microsoft HTML help template and FrameMaker 7.0 sourcefile, WW throws the following error: Wizard was unable to...
you need to add following entry to maker.ini file present in C:\Program Files\Adobe\FrameMaker7.0 location
Under section API Client add following line
WWPPE7=Standard,WebWorks Professional Edition Plugin,C:\Program Files\Quadralay\WebWorks Publisher Professional Edition 7.0\bin\wwpfm7.dll,all
Please note that path given to wwpfm7.dll may defer depending upon your webworks installation directory
Thanks
Rohit
May 07, 2010 | Quadralay WebWorks Publisher Professional...
Need other software to open Publisher files
You can try Scribus. It's an open source app and it's free.
hope this helps . . .
Apr 07, 2010 | Microsoft Publisher for PC
I have picture publish 7 cd but it will not load on windows 7
right click>properties>compatibility>change to another version of windows and run as admin. or rightclick the setup file on the disk and hit run as admin.
Dec 10, 2009 | Micrografx Webtricity 2.0 Full Version for...
Photographs randomly disappear each time a document is used.
Before you open up Publisher and this document, open up task manager and note how much RAM is used as well as your paging file usage. After you open the document, take another look at your RAM and paging file usage again. If both have increased dramatically, you may want to use smaller images (via compression for JPEG files or lowering the resolution of the images first). Or you could invest in more RAM for the computer.
Jul 03, 2009 | Microsoft Office Publisher 2007 for PC
.pub File unable to open after Microsoft Publisher hung
you could try open office and see if it may open it? worth a try. also try right click-properties-general tab and check file size, if its 0 then its lost.
This being said you can still go into the properties and check shadow copys.... if you saved it before you can try to find the deleted file.
there are free programs to recover lost files.
just Google "file recovery"
Hope this may help you
Jun 23, 2009 | Microsoft Office Professional 2007 Full...
The disc arm for the bravo disc publisher primera is telling me that the disc was not picked up, and to press the left button on the machine to try again. I have done this plus I have turned off both my...
hi,
i think you already need to clean your equipment.
this is part of the manual of your equipment and follow their tips to prevent damage.
go to this link: http://www.primera.com/manuals.html
to download the files.
Section 5: Maintenance and Troubleshooting
A. INTERPRETING THE PUBLISHER’S INDICATOR LIGHTS
The Power/Ink button can tell you what is happening inside
the Publisher. Please refer to the following:
Power/Ink Button Publisher
Fast Flashing The Publisher is initializing.You will see this
pattern when the Publisher is first turned on.
Wait until the lights stop blinking before
opening software or starting jobs.
Slow Flashing The cover is open and the ink cartridge carrier
is in change position. Insert a new cartridge
and close the cover. (The slow flashing light
can also indicate an out of media condition,
a robotic error or a picking problem. However,
these conditions are always paired with a error
message on screen.)
B. CLEANING THE PUBLISHER
NOTE: Do NOT attempt to oil or grease the Publisher's Robotic Arm shaft
or other components. You will likely cause more harm than good!
Any moving parts are designed to operate for the life of the machine
with no additional lubrication required.
Use a clean, lint-free rag with a small amount of ammonia
window cleaner to clean the Publisher's outside case and
trays. This type of cleaner is very effective on inks that may
accumulate on the printer tray. Stronger cleaning solutions are
NOT recommended because they may damage the paint and
plastic materials from which the parts are manufactured.
Always disconnect your Publisher's power cords before
cleaning. Resume operation only after the surfaces are
completely dry.
C. PERFORMING A ROBOTIC SELF-TEST
To ensure that everything is working properly, a Self-Test
feature is built in to your Publisher. In this mode, the Robotic
Disc Transporter will go through the motions of picking and
placing a disc to ensure proper working order. This test may be
performed without connecting the Publisher to the PC.
Perform the test by doing the following steps:
• Load some discs into the Input Bin.
• Open the cover.
• Press and hold the power button for five seconds. The test
will start.
• To stop the test, close the cover and press the power
button.
D. CLEANING THE INK CARTRIDGE
It may be necessary to clean the ink cartridge nozzles if you
notice reduced print quality, or if you suspect an cartridge nozzle
has become slightly dried out or clogged. If you are having
print quality problems, follow the steps below:
1. Remove the print cartridge.
2. Moisten a lint-free cloth with water.
3. Hold the cloth against the
nozzles for three seconds.
This will “wick” some
additional ink onto the damp
cloth.
4. Wipe in one direction only.
5. Repeat the process
E. TECHNICAL SUPPORT
If you have difficulties in operating your Publisher, the
procedures in this manual and the software User's Guide
should, in most cases, solve the problem. If you still have
difficulty, contact the technical support number listed on the
insert included in the supply pack that came with your
Publisher.
Source Location
Primera Knowledge Base www.primera.com/knowledgebase.html
PTPublisher Software Help files Open the software. Click on the ? icon in the
upper right corner of any screen.
SureThing Software Help files Open the software. Click on the Help
Menu - Contents
Email Support www.primera.com/contact_tech_support.cfm
Chat Support www.primera.com/knowledgebase.html
Phone Support 763-475-6669 (Mon - Fri 8 a.m. - 7 p.m. CST)
Nov 22, 2008 | Bravo Computers & Internet
Open files from different version of MS Publisher
I have a similar problem: Files were created in Publisher 2003. Then I had to reformat the hard drive and re-install Publisher 2003. Now I can't open any of my previous files even though created by the same program because "Publisher can not open files from a different version." Very frustrating. I hope someone has a solution. Alban Johnson.
Jun 26, 2008 | Computers & Internet
Microsoft Publisher 97 Full Version for PC Logo
259 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
