Question about Pioneer DEH-1900MP CD Player
Pioneer DEH-1900MP error AO
My radio keeps telling meerror ao, and now it dosnt read the cdor ejected,i dontknow what to do---please help me
Re: pioneer DEH-1900MP error AO
Turn off your car, turn key to ignition and as soon as your radio boots up, press the eject button. it should eject the CD. Loan a different CD to see if it works.
Posted on Oct 10, 2012
I have the same problem CD will not eject and getting error :S
Posted on Mar 01, 2008
0 characters
3 Points
My pioneer car stereo DEH-P77MP won't play cd's anymore. the radio still works, but on the screen it says cd error AO or A0. i was wondering what problem this code relates to? hope you can help,...
This is a common error with these units when they get dusty from putting dirty disks inside the drive. Just go to your local staples and or walmart and get a 5 dollar disk player cleaning kit. It looks like a plain cd but has small fibers that come out of the bottom of the disc that clean the laser as it spins and tries to read it.
May 09, 2011 | Pioneer DEH-P77MP CD Player
I get error ao on my cd player when it reads a cd
are you useing cd rewrights some cd players dont like them ? have you tryed a cd cleaner in it ? if not try that if it dont do the job your find the laser needs to be reset in side the cd player this sometime costs more that what the head unit is worth it might be cheaper to buy a new one . let me know how you get on
May 29, 2009 | Pioneer DEH-P2900MP CD Receiver...
Error a0
Do you have a code that you had to enter to unlock the stereo? Have you tried to reset the stereo? Look in your owner's manual and look for a "RESET" button. If you don't have the manual, you can download one from Hope this helps...
Aug 29, 2008 | Pioneer DEH-1900MP CD Player
Error ao pioneer head unit
If the discs PHYSICALLY get stuck, then the mech is damaged. A local shop MAY be able to fix it, but it might be a better investment to just replace the radio.
Aug 04, 2008 | Pioneer DEH-P6800MP CD Player
offtopicforum shittypantyes
Mar 09, 2008 | Pioneer DEH-1900MP CD Player
Error Message AO
I had the same issue, my battery was died due to headlight was ON and later player was showing AO. I am going to reset the unit and see if it will solve my problem.
Cd error-ao pioneer deh-77mp
I read a solution on here where you disconnect the wiring harness for 30-60 mins. to release the power stored in the capacitors. It seemed to work for everyone. I don't know if you tried this for this amount of time or not. Also, have you used a cd cleaner disc? You laser eye may be dirty. Also, since you said it was an old, battered car, maybe the vibration is causing the unit to malfunction. Also, if the unit is installed at the incorrect angle in the dash, it can cause a problem. Hope this helps...
Jan 16, 2008 | Pioneer DEH-1900MP CD Player
Ok so I just fixed my problem. Although I was getting the error because of using an iPhone instead of a CD I believe it is the same solution.
As jjgomex suggested it was pulling to much power, to what I did was turn on the headunit switch the source to something other than what causes the problem.
Then go to the Audio settings in the menu and turn bass all the way down and Sub Control to -1.
Then turn off headunit and turn it on again and switch to the source of problem, it should be fixed, or at least it did for me.
:) Good Luck!
Nov 14, 2007 | Pioneer DEH-P7500MP CD Player
DEH-1900MP - lost functionallity after disconect/connect batery
Yes for some radio's if you take away power it has a theft lock and will not let you back in except if you have the code. To reset you must take power away from it. I would suggest if you don't want to take cd player out of car then disconnect battery. then when reconnect eject. May have to set for a moment.
Sep 21, 2007 | Pioneer DEH-1900MP CD Player
sounds like slight vibrations from road are loosening a wire connection. re-check all wire connections
Jun 02, 2007 | Pioneer DEH-16 CD Player
Pioneer DEH-1900MP CD Player Logo
745 people viewed this question
Top Pioneer Car Audio Receivers Experts
xxxxxx xxx
Are you a Pioneer Car Audio Receiver Expert? Answer questions, earn points and help others
