Question about Yamaha HTR-5830 Receiver
Symbol for all speakers not illuminated ( the moon shaped symbols
Back surround speakers very faint and can't seem to adjust properly. Did factory reset which sounded even worse.
  • 33 Answers
Plug in the connecting wires correctly...
Posted on May 23, 2009
How do I fix my seem to be frozen Facebook app, everything else works perfect can you help me?
At first, u r activating "Don't disturb" mode. U need to disable it from control center (icon with half moon) or from the setting ( Don't disturb mode). if it didn't work after that, please reinstall Facebook app again after deleting it.good luck
Feb 12, 2015 | Apple iPad 32 GB 3G Tablet PC
What do symbols refer to ?
Are you sure the maple leaf isn't a snowflake?? The snowflake means cooling mode. The half moon means night time schedule and the waves mean the fan is on. The little flame indicates heating mode.
Jun 14, 2014 | Cfm Prem-I-Air PEVC797 Air Conditioner
I CANNOT GET THE WIRELESS REAR SPEAKERS TO WORK. ALL I GET IS A VERY FAINT STATIC.
I just fixed this problem with my theatre system. First, if you use speaker wire and not plugs, pull out, than reinsert the wiring, sometime it doesn't properly connect. Make sure that your sound field is turned to Surround Sound. Funnily enough, these are the two most common issues.
Then check rear speaker volume. If there is a switch or button to choose A, B or A+B speakers, attempt adjusting this.
That should do it. Even if you're not playing surround enabled content, but to be safe, ensure you are.
Feb 28, 2011 | Samsung HT-C6500 Theater System
Using my Acer CPU, I successfully plug in the speakers to the green receptacle. Works find. But should I be able to connect a second set of speakers in another room, run in the wire and plug into one of...
the green plug is for sound OUTPUT (to speakers with an amplifier), the blue is for sound pre amp INPUT (like a MP3 player or a any other device like an old 4 track casset WALKMAN player) the pink one is for a MICROPHONE INPUT, the black is for a surround system OUTPUT, and the yellow is for a digital OUTPUT all for a surround 5.1 system, so you have to look closer you will notice some difference in the icons stamp in the back, green has a sound wave symbol with an arrow going outwards the pink one has a sound wave symbol with a MIC symbol, the blue has a sound wave symbol with an arrow going inwards, the black and the yellow has a sound wave symbol with a digital symbol
conclusion... you can use the green OUTPUT to feed to one amplifier, if you want to feed music to multiple amplifiers you need a SOUND MIXER with at least two outputs, you can buy a chap sound mixer for about 20$, go to your local electronic store and EXPLAIN EXACTLY WHAT YOU WANT TO DO and they will sell you exactly what you need...
Hope this helps!
Feb 22, 2011 | Acer 90.00012.30B Computer Speakers
Symbol scanner LS2208-the laser light is very faint and is not scanning books. It was working correctly last Friday. Can anyone tell me what I can try?
Hello Shulgirl,
this seems like an hardware issue, just contact your supplier. Those scanners are covered by 5 years warranty. You probably get an replacement for your faulty device.
Nov 01, 2010 | Symbol LS2208 Handheld
Moon
If the shape of the symbol is the cresent moon....then that is the "Sleep" shortcut key. It will send the hard drive into standby mode. In a lot of systems, this sleep mode can really corrupt and damage system files. I always recommend disableing sleep mode in the power options section of the control panel.
May 24, 2010 | Compaq Keyboard
If the spanner symbol on a fiat ducato dash is illuminated and the vehicle was only serviced and Mot'd 3000 miles
are you trying to figure out why the "spanner symbol is illuminated" after the vehicle has been serviced? I would take it back to the place you had it serviced and tell them about it.
Jan 23, 2010 | 2006 Fiat 124
Not recognizing the speakers.
Operating systems don't auto detect speakers. You have to go into the sound setup in Control Panel and you can tell the computer if you have headphones, surround sound, 2 speaker, 4 speaker setup or whatever. If your sound just isn't working then you need to go into or sound card setup and probably tell it what you have plugged into each jack or let it auto detect your speakers.
Oct 18, 2009 | HP Pavilion Media Center TV m7360n...
One tel magma 300 - can't change message on answerphone
1) Press the 'tape' symbol to access the answering machine mode.
2) Press 9 then 1 for 'answer and record'.
3) Whe you hear a 'beep' speak your message. Whilst recording the display shows REC OGM1 or REC OGM2
4) Press 5 to stop recording. Your message is played back to you
5) Press 'tape' symbol to exit.
To check your Out Going Message (OGM)
1) Press 'tape' symbol
2) Press 6 then 2 and the message is played back.
Jan 26, 2009 | GE 29888GE1 Digital Answering Machine
Speakers
Any make should do, just be sure the ohms match or else you run the risk of damaging the speakers if they are under rated, or the reciever if they are overrated. Usually it can range from 4 to 8 ohms, which is represented by a horseshoe shaped symbol.
Feb 11, 2008 | Jamo DMR 60 DVD Player/Receiver
Yamaha HTR-5830 Receiver Logo
186 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
