Question about Kenmore Dryers
No heat in my stack-pak kenmore dryer. The element is ok and there are no broken cables/wires. 220 does come in to the unit and show up at the componets.
  • 1 more comment
  • ssv01 May 23, 2009
    mdl 110 98575820
    mdl. 110 98575820.
    Thanks a million.
    Vern
    Thank you. It works when I connect the termals togather and run the unit. I now know what to order thanks to your help.
    Vern
  • Kenmore Master
  • 3,361 Answers
There is a thermal relay switch that is blown. Replace it.
Model number please and I will give you the part number.
Posted on May 23, 2009
  • steve
    steve May 23, 2009
    Your model number will not come up on the SEARS parts site.
    However, If you check the hi limit thermostat attached to the heat canister with a meter you will probably find the relay to be open. It will be the one that also connects to the heater element. If so, replace the high limit switch. Also look on the canister up high for a thermal relay. If it is open replace it also. They usually come in a set with the high limit.
Dryer not heating
Check Heating elements if ok check the in line fuse that go to drying element and if it open replace it and clean filter and check pipe that blow out side make sure it not stop up because if in line fuse is open stop up filter and pipe that blow air out side will cause the heating element in fuse to open up. And check for lose wire going to element to.
May 30, 2014 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stacked laundry unit. when it was plugged in sparks flew and small parts of the heating element fell and the power cord is ow black. can we replace cord and be ok
Heating element must be replacedas well as the cord. Make sure the drum screws were not screwed into anything electrical.
May 18, 2013 | Kenmore Dryers
Stacked dryer will not heat?
Possible failure of the heating element.click Element
Jan 21, 2013 | Kenmore 98702 Stacked Washer/Dryer
DRYER RUNS BUT NO HEAT.WHERE CAN THE FUSES BE ?MODEL NO 970-17802-20.SERIAL NO XE73210031.KENMORE
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
The heating element won't get hot? Each wire to the element is getting 110v, but when checked together i am not getting 220v to the element?
Hi: 220 volts to a dryer are two 110 volts combined. Two separate wires. Did you check the heating element? See if it's broken. If so replace it. FIRST, Another thing to check is your circuit breaker. If it has only one side blown you will show 110 volts but that's all the dryer will get and dry slowly. The washer will still work as it's only 110v. I hopes this helps, Jeff
Jun 07, 2009 | Kenmore 88752 Top Load Stacked Washer /...
I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Mar 17, 2009 | Kenmore Dryers
Dryer tumbles won't heat
The problem could be related to one of the following; Not enough power from the house, a bad or broken heating element, a bad thermal fuse, or a brake in the wiring.
Solution
Check the house voltage for 220-240
Do a continuity test on the heating element.
Do OHM reading on thermal fuse.
Check wiring to heating element.
Aug 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer no longer heats up on my Kenmore 417.94812301 laundry stacked unit
On your dryer the common problems found is either you lost some of your electrical power (check your fuse box) or you need a new heater #131475300 about $100 for the part.
Jul 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
146 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
