Question about Garden
Lawnboy 10301 won't start
Mowed grass yesterday, now won't start, replaced spark plug gapped correctly, primer bulb working correctly. HELP! I have more grass to mow and can't get the thing started.
  • Anonymous Mar 31, 2014
    my lawnboy will run for 10/15 mins then stop after it cools it will do the same again takes forever to cut grass
    Problem Solver:
  • 11 Answers
You need spark, gas and timing to make it run. have you checked spark? sounds like you are getting gas. did you hit anything hard with the blade while mowing? this can throw it out of time.
Posted on May 23, 2009
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
Spark plug has no spark
Check the on/off switch, Check the timing gap between the flywheel and ignition module.
Jul 29, 2013 | Garden
Victa v160 runs for a while then stops
Ignition module is failing
Oct 14, 2012 | Garden
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
My neighbor gave me a Poulan mower that doesn't work. I am trying to trace the problem but don't really know what I am doing. It doesn't start. It has a new spark plug that I can only assume is gapped...
Remove plug, with plug wire connected to plug ground plug to the head and pull you should see a spark. If not if your mower has safety swithes you may have to jump around them.Or relace ignition unit. If you got a spark, try putting a little gas in the spark plug hole before putting plug in. If it pops then you probably have a fuel problem.
Sep 28, 2010 | Poulan Garden
Echo Blower PB-403T will not start. I replaced the air filter, fuel filter and spark plug. The fuel line inside the gas tank had broken off at the top. I reconnected and it still will not start. Previously...
Should be two fuel lines coming from fuel tank grommet. One feeds the carb's primer plate and the other returns from the same. Open the fuel tank and observe while pressing the primer. If you see fuel pumped INTO the tank while pushing the primer and pulled FROM the tank when the primer is released, you're OK. If not, the lines are backward. Filtered line is on SUCTION side of primer bulb. Unfiltered line is on PRESSURE side of primer and is simply a return to the tank.
Next, concerning the coil: Air gap should be .010 inch at the magnet. Echo ignition coils are warrantied for life to the original purchaser, so don't tamper too much with it. Check gap and check fire with a spark tester. If no spark with switch in on position, take it to an AUTHORIZED SERVICING dealer, found here.
Hope this helps,
Dolf-
Oct 15, 2009 | Garden
Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
337 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
