Question about Hoover U6311-930 Power Drive Bagged Upright Vacuum
Hoover power drive u6311 - How do u change switch? Does anyone have any idea how to remove the on and off switch, when I tap on the housing the motot and light goes on and off. Also does somebody have a exploded view of this model. also does anyone know the part number of the switch.
    Problem Solver:
  • 15 Answers
The swrtch is located in the bottom section of the motor. When the swtcih goes out it time to repalce the unit. The swtich is part of the motor. The switch rod run all the way down the body to the swtich located in the motor.
Posted on May 25, 2009
Hoover power drive supreme has no suction
If there is no suction at all, not even a little bit, then most likely the suction fan is broken. They aren't too complicated to replace if you want to.
Jun 08, 2014 | Hoover U6311-930 Power Drive Bagged...
How do I change the belt on my Hoover U6311-930?
At the front 2 screws hold on the front cover if you remove them you will be able to access the brush roll and belt
Feb 27, 2011 | Hoover U6311-930 Power Drive Bagged...
Indentations left on carpet all about 3 inches apart
The indentations that the Hoover U6311-930 self propelled leaves are from the two large wheels of the self propelled system under the bottom of the vacuum. There are two main reasions for this the weight of the vacuum cleaner and that the carpet fiber has worn, do to age, and now shows the tracks. There is no sollution for this problem.
Apr 08, 2010 | Hoover U6311-930 Power Drive Bagged...
Is there a switch to turn-off the tools so that
On the Hoover U6311-900 there is no switch that turns off the suction to the tool hose. That hose is attached to the head of the vacuum on the side via a spring loaded "door". Just twist the hose to remove it, the door will close and you will have full suction again.
Apr 06, 2010 | Hoover U6311-930 Power Drive Bagged...
I just bought a Hoover Power Drive Concept Two Electronic vacuum from the thrift shop. It only needed two belts and seems powerful. But i don't understand what the small red button on the handle marked...
The U6311-903 is a self propelled vacuum. The the small red button will stop the handle from moving back and forth, which makes the machine go foward and backwards. The red button disengages the self propelled feature.
Feb 06, 2010 | Hoover U6311-930 Power Drive Bagged...
Hoover Power Drive Supreme - Locked Up!!
Q: Are you talking about the turbine powered hand tool that attaches to the hose? If so, just squeeze the two round pins on the sides, and the housings will separate.
Oct 03, 2009 | Hoover U6311-930 Power Drive Bagged...
Hoover power drive vacuum cleaner simply shut off and died
my hoover vacuum is very hard to push forward but easier coming back.Any help will do.
Jan 24, 2009 | Hoover U6311-930 Power Drive Bagged...
My hoover power drive vacuum simply died. It just shut off. I checked the plug, etc...I just can't get any power...Can you help?
If no light or motor sound cord is probably bad. Look near AC plug or just replace the plug end. Check with ohmmeter for continuity with switch ON.
Power drive
it could be but i dont have enough info to really help. if the brush isnt working it could be power from the handle, it could be a bad motor, it could be even as simple as something is tangled up in the brush and that will stop it from turning but you can normally smell burning rubber when this happens from the belt slipping. please give me more information. so i may help. thank you james klgr
Dec 09, 2007 | Hoover U6311-930 Power Drive Bagged...
Hoover U6311-930 Power Drive Bagged Upright Vacuum Logo
212 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
