Question about Kitchen Ranges
Oven door is locked . View panel says F5 E7 - Kitchen Ranges
    Brigadier General:
  • Kitchen Ranges Master
  • 3,614 Answers
F5 means either "Failed transistor" or "Replace door/latch switch". You need a VOM meter to test the unit. Better for you to call for repair if you have no idea how to repair and service the unit.
Let me know for further clarifications
Posted on May 23, 2009
My oven is locked. Display shows F5:E7 How do I unlock it?
Vera, Code F5 E7 your latch assembly has failed. Turn oven breaker off to the unit for 5 min. to see if it will reset. If not, then try to set the self clean, wait 1 min. and cancel it to see if that will reset the door latch. If it does not reset the door lock, then you will have to manually open the door and replace the door latch assembly. It's not easy task to unlock the door. You'll need to use a coat hanger and pull the latch assembly from (right - left) by slipping it down between the door and the oven top. Force the latch over to the left and open the door, then you will have access to remove latch.
press the helpful button and follow me on fixya for more tips and info
Appliance411 FAQ After self clean range oven door won open
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0ahUKEwj-qYvv3ffKAhVHKh4KHdaUBgAQtwIIKTAD&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D320yZMp34oA&usg=AFQjCNE0dH2xRKfdY8alz0y7MdjMT86ULA
http://products.geappliances.com/appliance/gea-support-search-content?contentId=16246
How to Troubleshoot the Door Lock on your Stove Range
Feb 14, 2016 | Kitchen Ranges
Self cleaning oven
Pheo,
Turn Breaker/Fuse for the stove, your electrical panel, “OFF” and then “ON”, wait 20 - 30 seconds and the door should unlock.
It may be that the temp sensor is going out and you'll need to have that looked at soon.
Bill
Nov 21, 2007 | Whirlpool GBD307PDS Electric Double Oven
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I was cleaning my self cleaning whirlpool accubake oven and a F1 and E7 code appeared. I have just bought my house and the prior owner did not leave any manuals. Help please
Most Whirlpool appliance manuals are available from Whirlpool: http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . You will need the model number from the oven. This should be located behind the oven storage drawer on the rim. It will usually be on the left for a range and on the right for a wall oven. On rare models the plaque with the model number will be behind the door. If you add a comment with the model number, I'll try to post a direct link to the manual.
Are you sure about the error code? F1 and E7 aren't in my code books. I have an F7 and E1 code that indicates a short between the door switch or latch switch and the chassis or ground. (For double ovens, there are two of the switches for each door. The code doesn't specify which oven has a bad switch.) The F5 E7 error is a door latch that will not unlock. An F3 E7 error indicates that the warming drawer sensor has shorted out.
For the F3 E7 error, simply replace the sensor. For the other two errors, the solution depends on the door lock state. You start by unplugging the oven and checking all the wires and their connectors. See http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes for the complete set of steps. If the wires/connectors are okay, you probably need to replace one of the door switches if the oven door was locked when the error occurred. If it wasn't locked, then you can check the voltage to the various switches and replace any that are bad. If it isn't a switch, then it is the control that has failed and must be replaced.
I hope this helps.
Jul 02, 2011 | Ovens
Error code F5:E7 Can not get the oven door unlocked or reset this code. What do we do?
Beginner on forumn, don't have any manual in front of me on f5:e7. Sounds like a conventional oven problem, oven door locking. If in fact is some form of conventional heat oven (convection?), I had similar problem with a GE range, it flashed some kind of code seams like which I later interpreted by using owner's manual that explained codes. In my case it was in "cleaning mode" and you can't turn that off unless you unplug or turn breaker off, that puts it back to default mode with nothing running. I simply tried out the self cleaning feature, from there the oven went to full on heat and oven door locked unexpectedly. I learned stays locked till cycle finishes and oven cools, which is some time after the oven automatically switches off, said that it can be a couple of hours before you hear a...click, and now door opens (note to self, don't ever do that again).
Jan 13, 2011 | KitchenAid Microwave Ovens
My display reads F5:E7 on a Kitchenaid Superba stove. email cmaffey@hotmail.com
Well, its 10:30 on a Saturday night, and I was so frustrated by my Kitchenaid Oven. I set it to clean, but afterwards it would not unlock. the display read F5:E7, which i found out means the door unlocker won't work.
So, how did i fix it, well there are two ways, to get your oven door open.
I only found this out after tinkering for 2 hours, and found the easiest way to get your oven going again:
Pull your range out so you can see behind it. You will see a rod in the upper center part of the oven. There is a cutout in the metal and you can see the solenoid that locks the oven. It is connected to a rod. This rod is what goes to the front of the oven and is what is keeping your door locked. Simply move that rod the opposide direction, it will click, and presto, your door is now open.
I never bothered to replace the solenoid, because I didn't know if it was bad, or the controller board. The Solenoid itself is $90, I don't want to even guess what the control board is.
So, not technically a fix, but it will get your oven open. Just don't clean it automatically any more!
Sep 30, 2010 | KitchenAid Ovens
Our Kitchen Aid Superba range has its door locked and the touch control panel is not working. The screen shows F5:E7 in the clock area. How do wee fix?
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Sep 05, 2010 | KitchenAid Kitchen Ranges
Kitchenaid gas/convection stove oven door locked & won't open
Remedy:
1. If door latched:
  4. Re-apply power.
Note: Applies to all F5-E... codes.
Sep 17, 2009 | Ovens
Oven door locked
unplug the oven for a few hrs, need a brand and/or model number to look up diag. codes
Jun 02, 2008 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
