Question about Acer AL2423W LCD Monitor
No signal box in middle of screen
My monitor has started showing a 'No Signal' gery box of the middle of the screen. Checked H drive with providor....no issues. Monitor blackouts regularly ( 5 sec )??
  • mattferris May 23, 2009
    All good
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Try a different monitor to make sure your computer boots up properly.
    If it does, then we know for sure your computer is okay.
    The monitor your having problems with, does it have a vga connector and a dvi connector, or just one connection?
  • 53 Answers
I had this happen to me and it was the video driver that went out, if you have or r using the video slot or monitor slot already on the motherboard you can get a video card to put in a slot on the mother board and it should solve the problem....hope it helps ....shia
Posted on May 23, 2009
No Signal
check the settings carefully
Aug 22, 2012 | E-Machines eMachines Desktop PC
Samsung Syncmaster 2333
Check signal cables means there's no signal on input. If your PC still shows up on a different monitor then it's a time to replace a mainboard in your monitor.
Jun 03, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
"Input signal out of range"
usually points to the resolution settings of the graphics card not matching the monitor resolution settings. Reboot to safe mode on the computer and set the resolution to a lower one. A good starting point would be 1280 x 960 at high res. See if that works
Jul 09, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
VX922 only shows "No Signal" on black screen
The monitor shows no signal probably it didnt detect the tower
Ill be advising you to remoev the cable that conencts the cable
used a clean cot or rug clean both ends of the cable , clean also the area whre you plug in the cable , the ports on the monitor and on the CPU make sure its clean .
Then plugged it in , in case nothing happens
try to used another cable that conenct from the monitor to the CPU
you may aslo try to used other CPU to checked if monitor is working fine or try other monitor to checked if the port on the your CPU is working fine
May 23, 2011 | ViewSonic VX922 19" Monitor Flat Panel
I work with 2x193W LCD Monitors together. One is working fine, the other is now giving me the "No signal" screen. I have checked connections and pins. Everything seems alright. What am I missing?
Open you video cards control panel and check the display settings. Check to see if it is set to duel view or single display. You can also open your display settings for your computer. Under the settings tab choose which monitor is showing no signal and make sure it has a check mark on the box that says extend my windows desktop onto this monitor.
Jun 08, 2009 | Acer X193W LCD Monitor
XO Vision GX-1581 No Signal
It looks like you've narrowed it down to a settings issue. If it is saying "No Signal" while on AV2, then you need to switch to AV1 where your video signal is. A remote might be available online from XO Vision (www.xovision.com) directly or on E-bay. You might also be able to find a local dealer of XO Vision from their website. One quick fix you can try....since the monitor has 2 video inputs and is stuck on AV2, you can simply get video by unplugging the video input on AV1 and plugging it into AV2. Hope this was helpful.
Sep 27, 2008 | XO Vision GX828 8" Roof Mount TFT LCD...
Cannot remove "input signal out of range"
input signal out of range would normally indicate the the screen resoloution is either too high or too low for the monitor to display properly.
is this on just one game? which version of windows do you use?
Jun 21, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Acer AL2423W LCD Monitor Logo
280 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
