Question about Magic Chef CGS3760 Gas Kitchen Range
Can't get cook top open
So I lifted up the cook top to look at the underside and both of the gas lines to the front burners broke. Now I can't figure out how to get the cook top up so I can replace the gas lines without breaking the lines to the back burners.
    President:
  • 1,136 Answers
Hi, the burners turn counter clockwise. they hold the burner to the top panel. Those need to be removed. Most of the time the tubing is disturb like this, they need replaced as well. Please let me know if this helps or if I can assist you further.
Thanks
Vic
Posted on May 23, 2009
How do i change a whirlpool model wbp88800 burner control
Unplug stove. There should be two screws under edge of the cook top. You need to open oven door to get at them. Remove screws, lift cook top up at the front and prop it up. There will be two or three screws with spring clips holding the burner to the cook top. Unplug the connections, remove screws, remove burner. Install in reverse. I did this at Christmas just in time for dinner. It takes about ten minutes.
Feb 06, 2015 | Whirlpool Kitchen Ranges
I want to lift the cook top on GE range jbp82shss so that I can clean out all the dust. can I do this
Yes. Disconnect power to range. Open oven door and remove hex head screws at front edge of cooktop from the bottom side. Lift up front of cooktop. Burner units can then be removed from the underside of the cooktop. Be careful not to damage the gray insulating material around the burner elements if you remove the elements from the cooktop glass.
Mar 05, 2011 | GE JBP82SHSS Electric Kitchen Range
Parts Replacement
twist the burner to releace them . remove all 4 and the screws around the sides the lift top .. cook tops have to be completly disambled . for service .. mm
Jun 29, 2010 | Maytag MGC5430BDS Gas Cooktop
How do i replace the surface element for a glass top cook top range
The cook top on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the front edge of the cooktop. You will need to open the oven door to see them. Then, just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There is dangerous voltage still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the bad surface element by removing only the bracket pair that the affected element is attached to. Leave the rest of the elements wired together. Write down the wire color codes so you can be sure the new element is installed correctly. HINT: A digital camera can save you some time.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. The elements are fragile.
If the wiring harness does NOT unplug, prop the cook top in place and install the surface element from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
If you have any questions about this repair, please let me know. You can reference searspartdirect.com for some helpful exploded view diagrams of you range for assistance if you need it. I hope you find this information helpful.
Nov 17, 2009 | Whirlpool RF364 Electric Kitchen Range
Opening the cook top in a Whirlpool electric range
The cooktop on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the frotn edge of the cooktop. You will need to open the oven door to see them. Just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
Nov 12, 2009 | Whirlpool RF378 Electric Kitchen Range
Stove burner gets red hot
Since you do not have a thermostat control on your burners, I would suspect you may have an infinite switch (burner control), that controls that particular burner, possibly starting to go bad. The thermostat control is located on the infinite switch itself and may be cycling on and off improperly. Its hard to tell with intermittent problems, however. If in doubt, you can do a comparison between a working 8" inch burner and the one you are having problems with.
Another thing to consider with these coil type plug in burners, the receptacles under the cook top that they plug into can gradually become loose over time and cause the burners to arc. This may also cause excess current flow through the burner and will eventually cause burner coil damage and/or receptacle failure. I would troubleshoot this by, first, by unplugging the appliance and inspecting all the burner receptacles. If any show signs of burning or melting, replace them. You will need to lift the cook top to access them. Locate the screws under the bottom front edge of the cook top (open the oven door to see them) and remove them. With the screws removed, the cook top will lift up. Prop in place using the hinge supports.
NOTE: Remove the burner coils and bowls before lifting the cook top.
Replacements parts (including burner receptacles) can be purchased at pcappliancerepair.com, appliancepartspro.com, searspartsdirect.com, or repairclinic.com.
If you have any questions, please let me know. I hope this helps you.
Aug 02, 2009 | Kitchen Ranges
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
Want know how to open the top of range to clean?
This is not really meant to be done by user. If done incorrectly you could easily bend or break the gas lines to the top burners.
First you need to remove all the screws in the top burners and remove the burners. Then carefully twist out the ignitors. They do not necessarily have to be disconnected. Then remove all the knobs in front. and remove the manifold cover (that's the cover behind the knobs).
You will then be able to remove the screws that hold the top down and lift the top up high enough to clean under it. Lift this carefully though making sure that the gas lines do not bend when you do it.
Nov 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Model RDSS30QW X-LO Burner Problem
remove 4 screws under the trim that surrounds the burner knob panel. They are on the underside and you will be looking straight up to see them.
Slide the trim down and off after removing the screws.
remove the burner grills and caps
remove the 4 brass venturis and you will then be able to lift the cooktop
the valves are easy to get to
May 10, 2007 | Thermador RDDS30 Dual Fuel (Electric and...
Magic Chef CGS3760 Gas Kitchen Range Logo
193 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
