Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hydrostat trans starting to make moaning noise stops pulling
Cub cadet 1500 series hydrostat trans starting to moan stops pulling forward\backwards cools down will pull good till it gets hot
  • Anonymous Mar 21, 2014
    I found the oil milky -water- when I opened it and it was starting to overheat after say 20 minutes and if I cool it down with a hosepipe it would be good for another 20 minutes..could some parts being damaged by the water content in the oil
  • 351 Answers
It may be full of dirt etc and has soaked up most of the oil inside the case, if the axle seals are worn and the selector shaft seal is worn I would say that is the problem, if that is the case you may be up for a new trans as I have done a transaxle just recently and the damage inside was extensive and expensive.
you will have to remove the trans and seperate the trans case for inspection
Hope this helps
Posted on May 23, 2009
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling
Because I didn't know they used 2 belts in the diagram on parts tree.com . I bought the 79" belt and not the 78" belt.
Aug 22, 2014 | Cub Cadet Garden
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
you need to change thr hydr fliud in the transmission and the filter
Cub cadet hydrostatic
brake lever on trans could be stuck on lay down and push lever to free up
Jun 04, 2013 | Garden
On my cu cadet zero turn only the left side turns and the right side moans but wont move ever with the release lever to free wheel released
Check the hydraulic oil level for the hydrostat drives(if it has a reserve tank located under the seat. Some ZT's don't have the reserve tank. Don't over fill that tank. 1/4 inch above the bottom is all it needs.)
Also, check the steering arm bolts. Very often they work themselves loose and the arm doesn't pull the valve rod that controls the hydrostat unit.
Oct 21, 2009 | Cub Cadet Street Sign- tractor lawn riding...
89 cub cadet, 1420, hydrostatics trans, moves very slowly forwards & backward
check the drive belt for ware could be slipping or might need to add oil to rearend
Sep 21, 2009 | Garden
On my 2007 cub cadet zero turn my right wheel will stop working
This does not sound good if its still under warranty get it back there asap... sounds like a lazy drive weather its juat a faulty drive or your hydro pump not feeding that side, it should not be unservicable after 90hrs... even if its out of warranty get it fixed asap as the metal may spread to your pump or other drives and that will be very expensive.
brad:)
Sep 13, 2009 | Garden
Problem with left side hydrostatic transmission
This is a well documented problem with cub cadet ZT transmissions. They tend to go bad after 200 hours of use. Sometimes having the dealer change the transmission oil will help (they need to remove the transmissions to do this!). Most times, the transmission is gone & must be replaced ($800-$900).
Sound to me like a design defect. My ZT-50 lasted only 4 years. Needless to say, the replacement was not a cub cadet.
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
607 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
