Marantz receiver the receiver is popping and crackling when power is turned on how do I clear this up?
    Problem Solver:
  • 8 Answers
You have a worn power switch. After 30 years of turning a powerful receiver on and off, the contacts in the power switch become pitted and corroded, and just plain dirty - this is exacerbated in smoking environments. As the resistance in the contacts increases, it takes more "juice" to bridge the contacts, and this takes the form of hissing and sputtering. The best solution is to replace the power switch. These can usually be found on eBay for between $10 to $25 - just search for "Marantz power switch". You'll probably need to disassemble most of the front end of your receiver to get at the switch, and you'll need some soldering experience and tools to remove old and install the new. Once you do the job, however, it should last the rest of the life of the unit.
Posted on Oct 19, 2009
SOURCE:
Just had Marantz 2235B serviced however after 2 hours of playing some vinyl, I hear fuzz and a pop in the left speaker. Now, no more sound from receiver.
Fuzz and pop sounds like bad capacitor or blown transistor.
Best to take it back to service center.
While there, throw your toys out of the cot, explaining that they did a 'b*m' job.
Jul 15, 2018 | Marantz Audio Players & Recorders
Tip
Marantz SR-7200 reset
This was documented on the Marantz website briefly a year ago and is no longer available. My SR-7200 develops "click/pop" problems and a reset cures it of these issues.
While powered "off," on the front panel, press: A/D + FP +Dimmer (3 buttons) and power the unit on.
This reverts to original (out of box) settings. You then must reprogram input sources, speaker setup, levels and radio stations.
on Oct 03, 2011 | Marantz SR-7200 Receiver
There is a crackle when i turn the volume knob.
First unplug it. Sounds like you need to spray some tuner cleaner in the pots that are crackling. Pull the knob off and you should be able to use a spray can of tuner cleaner with the straw that comes with them to spray into the potentiometer , then rotate the pot several times while it is still wet. After cleaning them all, wait 10 minutes and then try.
Jan 09, 2014 | Marantz Vintage Model 2220b Stereophonic...
2220 B
Do you mean just crackling generally or it crackles when you turn it up or down? I have a Marantz PM350, old but still great performance, and I periodically take the volume knob off and spray down the hole with a cleaner/lubricant spray. This does the trick!
Jan 08, 2014 | Marantz Audio Players & Recorders
I have a Marantz 2275 receiver hooked to some JBL speakers. I noticed one of the speakers crackling. I swithched the speaker wires around and now the other speaker crackles so I'm guessing it is
Doesn't sound like it's a speaker - more likely a fried chip or transistor causing harmonic distortion.
It's usually more cost effective to replace modern audio components than to fix them.
Nov 21, 2017 | Audio Players & Recorders
How to reset marantz sr4003
marantz SR 4003 how to reset (hard reset ) remove power plug from power .Take cover off locate ic 12 (24 c eeprom) short pin 5 to ground while plugging the power in .Unit will show clear on fl screen .if the unit trips again check channels.
Jan 04, 2012 | Marantz SR4003 Receiver
My Marantz 2270 sounds great when first turned on, for about 20 minutes. Then it starts crackling very loudly on both channels. Is it expensive to get this fixed?
No, it's not expensive to get fixed. The circuit board has over heated through time and some of the solder connection have weakened. Inspect the circuit board for cold solder connection and reapply heat and solder.
Nov 04, 2010 | Marantz Audio Players & Recorders
Need to give a FULL RESET in a MARANTZ SR5004 RECEIVER
Switch off the unit. Then hold down Sorround, Exit, Memory & Clear buttons all together and then switch on the power. This should work.
Jan 26, 2010 | Marantz Audio Players & Recorders
I Have an NAD 710 receiver, it crackled then volume went a little lower and when turned up begins to distort with no grunt, no longer crackles but the lower volume problem remains
YOU SOUND VERY KNOWLEDGEABLE IN THIS FIELD,BUT ITS BEEN MY EXPERIENCE IN THE PAST TO START SIMPLE(@ MAYBE YOU HAVE)SOUNDS LIKE THE SAME PROBLEM MY MARANTZ HAD ,IT WAS A SIMPLE MATTER OF TAKING CONTACT CLEANER TO THE POT'S & SWITCHES.(TRY SPRAYING IT DOWN THE SHAFTS;SWITCHES ,ECT....)MY MAIN PROBLEM WAS WITH THE A-B-C SPEAKER SWITCH,MUTE & VOLUME.AFTER WORKING THEM,THE PROBLEM CLEARED UP.DUST & BUILDUP(ALOT OF TIMES FROM MINIMAL USE OR STORAGE)CONTRIBUTE TO THIS PROBLEM;ASWELL AS CORROSION OF THE CONTACTS & COILS.GIVE THIS A TRY & SEE IF IT DON'T HELP.BEST REGARDS TO YOU ALSO;HOPE THIS HELPS.THAXNX FOR USING FIX-YA(PLEASE RATE)
Nov 08, 2008 | NAD Audio Players & Recorders
No output from left channel after crackling sound
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Jul 08, 2007 | Marantz SR-4200 Receiver
246 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
